Einleitung
I will teach you how to get down to the midframe. The steps are easy and fast.
Was du brauchst
Step 1- Use an opening tool, or your fingernail into the opening at the top near the headphone jack.
Use the tool or your fingernail to pry the opening open.
If an microSD card is inserted, use the flat end of a spudger and push it until you hear a click sound and it will release right after.
Do the exact same thing with your battery and do not damage the battery in any way.
Remove all six pf the 4.0 mm Philips #00 screws securing the back of the device to the front
