Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Samsung Galaxy S II zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: Schritt 1, Bild 1 von 1
    • Step 1- Use an opening tool, or your fingernail into the opening at the top near the headphone jack.
    • Use the tool or your fingernail to pry the opening open.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy S II Teardown: Schritt 2, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 2, Bild 2 von 2
    • If an microSD card is inserted, use the flat end of a spudger and push it until you hear a click sound and it will release right after.
    • Once you reassemble the midframe, place the microSD card back into it's slot
    • Do the exact same thing with your battery and do not damage the battery in any way.
    Frag FixBot
  3. Samsung Galaxy S II Teardown: Schritt 3, Bild 1 von 3 Samsung Galaxy S II Teardown: Schritt 3, Bild 2 von 3 Samsung Galaxy S II Teardown: Schritt 3, Bild 3 von 3
    • Remove all six pf the 4.0 mm Philips #00 screws securing the back of the device to the front
    Frag FixBot
  4. Samsung Galaxy S II Teardown: Schritt 4, Bild 1 von 1
    • Pry the midframe all around the device to carefully remove it
    • If you do not pry throughout the whole device, the midframe will be very hard to remove
    • A plastic tool opener would be better and it will not damage the phone.
    Frag FixBot
  5. Samsung Galaxy S II Teardown: Schritt 5, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 5, Bild 2 von 2
    • Remove the midframe carefully
    • If your previous midframe was broken, place a new one. When you hear a click sound throughout the device, you know you have snapped it into place
    Frag FixBot
Vanessa Cardenas
241 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 65
Insgesamt: 1,543
