Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Samsung Intensity zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Samsung Intensity Teardown, Samsung Intensity Teardown: Schritt 1, Bild 1 von 1
    • Remove the back cover and battery
  2. Samsung Intensity Teardown: Schritt 2, Bild 1 von 1
    • Remove the 8 screw that hold the back cover down.
    • Carefully pry back piece off
    • Start at the bottom and work toward the top.
  3. Samsung Intensity Teardown: Schritt 3, Bild 1 von 1
    • Use the ipod opening tool to disconnect the Connector
  4. Samsung Intensity Teardown: Schritt 4, Bild 1 von 2 Samsung Intensity Teardown: Schritt 4, Bild 2 von 2
    • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
  5. Samsung Intensity Teardown: Schritt 5, Bild 1 von 2 Samsung Intensity Teardown: Schritt 5, Bild 2 von 2
    • Remove the 6 screws
    • Pry to ribbon cable assembly loose from the slider
    • Its glued on the left and right side
  6. Samsung Intensity Teardown: Schritt 6, Bild 1 von 1
    • Remove the 4 screw the holds the slider to the phone assembly
    • one of the screws will be behind the hinge
    • Carefully pry slider assembly loose from display assembly
  7. Samsung Intensity Teardown: Schritt 7, Bild 1 von 3 Samsung Intensity Teardown: Schritt 7, Bild 2 von 3 Samsung Intensity Teardown: Schritt 7, Bild 3 von 3
    • Remove the tape and pop the connectors and pull all the ribbon cables loose
    • Carefully pry the speaker loose from the case.
  8. Samsung Intensity Teardown: Schritt 8, Bild 1 von 1
    • Carefully work the keyboard loose from the display assembly
    • There are a couple fragile clips that hold it in place
  9. Samsung Intensity Teardown: Schritt 9, Bild 1 von 2 Samsung Intensity Teardown: Schritt 9, Bild 2 von 2
    • LCD comes out pretty easily
    • Pry it from the bottom and work up the sides to release it if stuck
    • The glass can be removed with a little heat from a heat gun or blow dryer
    • Pry it out from the outside edges working around carefully
David
148 Reputation
1 Anleitung geschrieben
West Georgia Technology Mitglied von West Georgia Technology
Business
1 Mitglied
Ein Kommentar
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 4,680
