Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Samsung Jitterbug zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: Schritt 1, Bild 1 von 3 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: Schritt 1, Bild 2 von 3 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: Schritt 1, Bild 3 von 3
    • First remove the battery and rubber feet from base and under phone number inside.
    • Undo all six screws. Only the two under the battery will come out fully.
  2. Samsung Jitterbug Teardown: Schritt 2, Bild 1 von 2 Samsung Jitterbug Teardown: Schritt 2, Bild 2 von 2
    • Pop the six clips indicated in green and remove back. I removed the two on the sides first, but it was a huge pain to open the rest of the way. I suggest starting from the top four.
    • Blue is the connector to the screen and speaker board in the top of the phone.
    • Purple is the chip and orange is charging port.
    • The opposite side of the board (not pictured) has the microphone on it, it's a small black round bump on the bottom.
  3. Samsung Jitterbug Teardown: Schritt 3, Bild 1 von 3 Samsung Jitterbug Teardown: Schritt 3, Bild 2 von 3 Samsung Jitterbug Teardown: Schritt 3, Bild 3 von 3
    • Unhook screen connector and pop out board (just put a screwdriver under and pop).
    • Peel off button pad.
  4. Samsung Jitterbug Teardown: Schritt 4, Bild 1 von 3 Samsung Jitterbug Teardown: Schritt 4, Bild 2 von 3 Samsung Jitterbug Teardown: Schritt 4, Bild 3 von 3
    • Remove rubber front, then turn over.
    • Pop all five clips. Start at the top near the hinge and work down.
  5. Samsung Jitterbug Teardown: Schritt 5, Bild 1 von 3 Samsung Jitterbug Teardown: Schritt 5, Bild 2 von 3 Samsung Jitterbug Teardown: Schritt 5, Bild 3 von 3
    • Blue is main screen and mini screen board. Green is button and underneath is the main speaker. Purple is
    • Pop out all pieces. Be careful not to break the cabling connecting the outer bits to the board.
Kari Fox
125 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 2,101
