Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Was du brauchst
  1. Samsung SGH-A777 Teardown, Samsung SGH-A777 Teardown: Schritt 1, Bild 1 von 1
    • The Samsung SGH A777
  2. Samsung SGH-A777 Teardown: Schritt 2, Bild 1 von 3 Samsung SGH-A777 Teardown: Schritt 2, Bild 2 von 3 Samsung SGH-A777 Teardown: Schritt 2, Bild 3 von 3
    • Remove the black cover by sliding up.
    • Remove the SIM card(not shown) and battery.
  3. Samsung SGH-A777 Teardown, Removing the back cover: Schritt 3, Bild 1 von 3 Samsung SGH-A777 Teardown, Removing the back cover: Schritt 3, Bild 2 von 3 Samsung SGH-A777 Teardown, Removing the back cover: Schritt 3, Bild 3 von 3
    • Remove the six Phillips head screws. Keep track of their position.
    • Using a SIM removal tool or other small point, remove the bottom antenna cover. See photo 2. Place the tool in the bottom right corner and pry it off.
    • Using a spudger, carefully remove the antenna cover. Remove the two screws.
  4. Samsung SGH-A777 Teardown, Remove the back cover: Schritt 4, Bild 1 von 2 Samsung SGH-A777 Teardown, Remove the back cover: Schritt 4, Bild 2 von 2
    • Using a spudger pry the back cover off carefully.
    • Using your fingers or a spudger remove the two side buttons. Note their positions. These should easily pop off.
  5. Samsung SGH-A777 Teardown, Remove more screws: Schritt 6, Bild 1 von 3 Samsung SGH-A777 Teardown, Remove more screws: Schritt 6, Bild 2 von 3 Samsung SGH-A777 Teardown, Remove more screws: Schritt 6, Bild 3 von 3
    • Remove the two screws surrounding the camera.
    • Remove the two screws around the top of the battery spot.
    • Pry the black midplate off the phone.
    • Be careful as the screen is connected still by a ribbon cable.
    • Remove the entire Samsung model number sticker.
    • Slide the metal sliding mechanism up.
    • Remove the two screws.
  6. Samsung SGH-A777 Teardown, Separating the screen assembly: Schritt 8, Bild 1 von 2 Samsung SGH-A777 Teardown, Separating the screen assembly: Schritt 8, Bild 2 von 2
    • Carefully flip the motherboard up. Flip it from bottom to top.
    • Disconnect the ribbon cable with a spudger.
  7. Samsung SGH-A777 Teardown, Removing the backplate for the screen: Schritt 9, Bild 1 von 1
    • Pry starting at the bottom with a spudger. Remove the cover. This will require some force and a guitar pick.
  8. Samsung SGH-A777 Teardown, Remove the camera assembly: Schritt 10, Bild 1 von 1
    • Remove the daughter board and lift the small blue flex cable from the back of the LCD.
    • Remove just enough of the blue sticker to disconnect the orange flex cable. Flick the brown connector up and remove.
    • Remove the camera assembly.
  9. Samsung SGH-A777 Teardown, Remove the LCD: Schritt 11, Bild 1 von 2 Samsung SGH-A777 Teardown, Remove the LCD: Schritt 11, Bild 2 von 2
    • Using a guitar pick, carefully pry up the LCD shield plate from the sides.
    • Be careful not to crack the LCD. Don't touch the LCD!
    • Use a spudger edge around the edges of the lens. Remove carefully and use 3M to reattach.
  10. Samsung SGH-A777 Teardown, To remove motherboard:: Schritt 13, Bild 1 von 1
    • Flick the little brown connector up and remove the orange flex cable.
Josh Bacon
151 Reputation
3 Anleitungen geschrieben
Ein Kommentar
My cell phone SGH a777 has lost the sound and how to correct an entry does not function.
I want to have it repaired. Where should I bring it to have it repaired?
Vicente Paladin Molar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,979
