Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Dieser Teardown ist keine Reparaturanleitung. Um dein Samsung SGH-C450 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Remove the battery cover, battery and SIM Card.
    • Remove the battery cover, battery and SIM Card.
  2. Remove these screws.
    • Remove these screws.
  3. Insert yout flathead screwdriver or opening here and go around the device
    • Insert yout flathead screwdriver or opening here and go around the device
    • Gently pry open the case.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Once the case is removed you can see the PCB.
    • Once the case is removed you can see the PCB.
    • NXP OM6357EL4 ARM CPU
    • SPANSION Flash Memory
    • NXP CF50600 battery and power supply controller
    • SIM Card slot
    • EMI Shield
    • Battery Contacts
  6. To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
    • To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
    • To remove the EMI shield on the other side, remove these screws
  7. The IC's under the EMI shield.
    • The IC's under the EMI shield.
    • Skyworks SKY77518 Dual-Band GSM/GPRS Module
  8. Finished!
    • Finished!
Bryan
690 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 8
Insgesamt: 1,520
