Was du brauchst
If the screws are removed, you can take the case of with your fingers or a small flathead screwdriver
Now you see the PCB
Agere TR09WQTEF2B Processor
Agere PSC2106 Power Management IC
Battery contacts and power supply connector
SIM Card Slot
Back-Up battery
Antenna connector
2,5mm Headphone Jack
To take the LCD display out of the case, click the upper case open with a small flathead screwdriver or case opener. Under the two pads under the LCD Display are 2 screws.
Now you see this.
If you want to remove the LCD display, lift the PCB of the LCD display up with a small flathead screwdriver.
