Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Sandisk Sansa m230 Series mp3 player zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Sandisk Sansa m230 Series mp3 player Teardown, Sandisk Sansa m230 Series mp3 player Teardown: Schritt 1, Bild 1 von 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Teardown: Schritt 2, Bild 1 von 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Teardown: Schritt 3, Bild 1 von 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Teardown: Schritt 4, Bild 1 von 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Teardown: Schritt 5, Bild 1 von 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Teardown: Schritt 6, Bild 1 von 1
    • You now have access to all components found on the inside of the device!
James Thorne
638 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Mitglied von UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 2,721
