Zum Hauptinhalt wechseln
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
We disassembled this calculator on April 17, 2010.
Dieser Teardown ist keine Reparaturanleitung. Um dein Sanyo CX 110 zu reparieren, verwende unsere Fehlerbehebungsseite.
    • Here is the Sanyo CX 110 calculator.
    • Remove these two screws from the back of the calculator using a Phillips #0 Screwdriver.
  1. Now that we removed the back of the calculator, here is the battery and the back of the logic board. Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Now that we removed the back of the calculator, here is the battery and the back of the logic board.
    • Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Positive contact for the battery.
    • Negative contact for the battery.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  3. Remove these 7 screws using a razor blade.
    • Remove these 7 screws using a razor blade.
    • Be careful not to break the razor blade because it is fragile.
    • Turn the circuit board 180 degrees after removing screws.
  4. You will now see the circuit board and the buttons. Remove the buttons for the calculator. You will now see the circuit board and the buttons. Remove the buttons for the calculator.
    • You will now see the circuit board and the buttons. Remove the buttons for the calculator.
  5. Now we're all done! Just take the LCD apart and you are done completely!
    • Now we're all done! Just take the LCD apart and you are done completely!
    • Sum-3 Sanyo Battery.
    • LCD Screen Parts (darkener, inverter, LCD screen.
    • Circuit Board for the calculator.
    • Buttons for the calculator (square root, memory, percent, operators, numbers, etc.)
    • Housing for the calculator.
samhnri
417 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 4,943
