Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein External Storage zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Seagate 3TB Expansion Desktop Drive Teardown, Seagate 3TB Expansion Desktop Drive Teardown: Schritt 1, Bild 1 von 1
    • Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Once you have the end opened up, use the credit card to hold it open.
    • When you have the entire end separated, carefully pry the sides out and away along the adjoining two sides, working your way towards the end with the power jack. Save that end for last, it should lift away when you're done with the other sides.
  2. Seagate 3TB Expansion Desktop Drive Teardown: Schritt 2, Bild 1 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 2, Bild 2 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 2, Bild 3 von 3
    • Work around the drive, ends first then the sides to open it
    • This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
  3. Seagate 3TB Expansion Desktop Drive Teardown: Schritt 3, Bild 1 von 1
    • Gently pull the sides slightly and the drive will lift out
  4. Seagate 3TB Expansion Desktop Drive Teardown: Schritt 4, Bild 1 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 4, Bild 2 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 4, Bild 3 von 3
    • Pull the rubber screw covers off, these are mounted with a little glue and came off easily
    • Remove all four screws with the philips screwdriver
  5. Seagate 3TB Expansion Desktop Drive Teardown: Schritt 5, Bild 1 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 5, Bild 2 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 5, Bild 3 von 3
    • Slide drive out of metal caddy (do not lift)
    • You will now have a SATA Hard Drive and the caddy separate
  6. Seagate 3TB Expansion Desktop Drive Teardown: Schritt 6, Bild 1 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 6, Bild 2 von 3 Seagate 3TB Expansion Desktop Drive Teardown: Schritt 6, Bild 3 von 3
    • From the bottom of the caddy there are two black screws
    • With the Philips screwdriver you can remove these
    • Pull the circuit board gently and evenly to remove it
Edd
535 Reputation
2 Anleitungen geschrieben
3 Kommentare
if i add a different adapter that doesnt require power, will the drive still work?
sulz - Antwort
Does anyone know what to do if the Data port does not work ?
remus lungeanu - Antwort
Thanks... I probably broke every clip in the process, but I finally got it apart... Tested the drive in another external USB case and still can't see the drive, so my hope that it was the case circuitry that was bad was crushed... 3TB paperweight... Thanks Seagate :(
Sean Seoltoir - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 89
Insgesamt: 55,172
