Einleitung
This is a Sega Genesis model 2. In this tear down you will be able to see what the inside of the Sega Genesis should look like.
Was du brauchst
Remove the four outer screws (you may want a small cup to keep your screws in.)
You now have access to your circuit board. (If you wish to remove the circuit board, continue.)
