Einleitung
Alright. This guide is a teardown to show the safest and easiest way to take apart your genesis.
Was du brauchst
Let's start by taking the small door found on the bottom right side of your console
Carefully lift the top off of the console.
It should come off relatively easy
If it doesn't, ensure that all four screws are removed
Remove the six, gold, 8mm screws and the three, black, 8mm screws holding down the EM shield
After removing the screws, the shield will come off very easily.
Remove the two 17mm black screws on the left and right side of the PIN to release the circuit board from the bottom EM shield.
After the screws are releases, the circuit board can easily be removed from the console.
Well, there you have it!
One disassembled Sega Genesis. I hope this guide was helpful and informative. Good luck and Happy Gaming!
This guide brought to you by: Frankie's Video Game Console Repair and iFixit.
