Zum Hauptinhalt wechseln
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
Teardown of the Sky TV Remote, note: not Sky+ or Sky HD.
Dieser Teardown ist keine Reparaturanleitung. Um dein Sky TV Remote zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. This is it. Well, this is it in a functional state. Remove the batteries before starting! Remove the batteries before starting!
    • This is it. Well, this is it in a functional state.
    • Remove the batteries before starting!
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Use a Philips head screwdriver to remove this screw Use a spudger to unlock all the tabs around the sides, start at the bottom Work your way all the way around the remote, this is flippin' tricky.
    • Use a Philips head screwdriver to remove this screw
    • Use a spudger to unlock all the tabs around the sides, start at the bottom
    • Work your way all the way around the remote, this is flippin' tricky.
    • Brute force is compulsory.
  4. After all the tabs are off, the body should just fall away leaving the buttons, the circuit board, the case and the black infra-red bit at the end. Ta-daa! Ta-daa!
    • After all the tabs are off, the body should just fall away leaving the buttons, the circuit board, the case and the black infra-red bit at the end.
    • Ta-daa!
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 7
Letzte 7 Tage: 24
Letzte 30 Tage: 110
Insgesamt: 13,022
