Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Was du brauchst
  1. Sonos Play 5 Teardown, Sonos Play 5 Teardown: Schritt 1, Bild 1 von 1
    • Pull the front bezel forward to remove. It's only secured by velcro
  2. Sonos Play 5 Teardown: Schritt 2, Bild 1 von 3 Sonos Play 5 Teardown: Schritt 2, Bild 2 von 3 Sonos Play 5 Teardown: Schritt 2, Bild 3 von 3
    • Gently peel the rubber base away from the edges to remove 6 phillips head screw.
    • The base plate will lift straight up to reveal 3 metal stanchions. I believe these are the wireless antennas.
  3. Sonos Play 5 Teardown, Step 3 - Remove the 12 philips screws to release the Speaker panel from the case: Schritt 3, Bild 1 von 1
    • Of the 8 screws securing the speakers to the casing, two are hidden behind thick rubber bungs, which need to be removed.
    • There are also a number of smaller philips screws underneath felt-like padding on the base of the unit. These also need to be removed.
    • Much of the circuitry is covered in some sort of epoxy resin, making maintenance virtually impossible
Tim U
101 Reputation
1 Anleitung geschrieben
Ein Kommentar
This teardown is stale! Please continue. :) Thanks.
William Small - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 20
Letzte 30 Tage: 90
Insgesamt: 14,586
