Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony D-822K Car Discman zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Sony D-822K Car Discman Teardown, Sony D-822K Car Discman Teardown: Schritt 1, Bild 1 von 1
    • Obtain a D822-K Discman and remote. True, it has DSP and Surround Sound, but the 90's have come and gone. It's okay to take it apart.
  2. Sony D-822K Car Discman Teardown: Schritt 2, Bild 1 von 1
    • Position unit so that the bottom is facing up. Remove the 6 screws.
    • Hold top and bottom of unit together as you turn the unit over, bottom facing down. Use caution; the upper and lower case, along with circuit board are now loose.
    • Watch out for the AVLS and illumination switches, they love to disappear when unsupervised. Remove top of case.
  3. Sony D-822K Car Discman Teardown: Schritt 3, Bild 1 von 3 Sony D-822K Car Discman Teardown: Schritt 3, Bild 2 von 3 Sony D-822K Car Discman Teardown: Schritt 3, Bild 3 von 3
    • Removing the CD reader: Gently pull all 3 rubber grommets sideways, away from the CD reader.
    • Slide edge of ribbon cable connector towards ribbon cable to disengage.
    • Unplug the red, white, and blue plugs from the circuit board.
  4. Sony D-822K Car Discman Teardown: Schritt 4, Bild 1 von 2 Sony D-822K Car Discman Teardown: Schritt 4, Bild 2 von 2
    • Observation: This is the Hydro Suspension system...really.
  5. Sony D-822K Car Discman Teardown: Schritt 5, Bild 1 von 3 Sony D-822K Car Discman Teardown: Schritt 5, Bild 2 von 3 Sony D-822K Car Discman Teardown: Schritt 5, Bild 3 von 3
    • Remove circuit board
    • Notice the dual-color light modules. (I temporarily connected the power to show off the lights)
  6. Sony D-822K Car Discman Teardown: Schritt 6, Bild 1 von 1
    • Disconnect tailpiece, and power supply.
  7. Sony D-822K Car Discman Teardown: Schritt 7, Bild 1 von 2 Sony D-822K Car Discman Teardown: Schritt 7, Bild 2 von 2
    • Remote: Remove the 3 screws from the bottom. Pull apart.
    • The function buttons have a neat overlay design.
  8. Sony D-822K Car Discman Teardown: Schritt 8, Bild 1 von 1
    • Completely disassembled. The illumination button was lost for two weeks after reassembling... but who uses amber lights anymore?
modem21
84 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 18,063
