Einleitung
I will teach you how to deconstruct a DVD-ROM unit into it's base assembly and then show what many people use to build a burning laser.
Was du brauchst
Remove outside screws using a screwdriver that fits a M3x6 screw
Gently pry up the top casing with the model sticker facing down. Apply a wiggling motion side to side if necessary
Check for any remaining screws around the edge of the board, if there are none apparent double check the ribbons and the slide the board back until it slides free
To remove the tan plastic, ensure all of the screws have been removed on the metal tabs shown in red
apply a teetering pull apply more lift to one side that the other
Now most inside components should be loose and removable
This is a picture of the removal process of the laser diode component(it is still encased in the moving and refraction related parts)
Remove the three screws surrounding the second component
Remove and check for removal of all ribbons on this component(note the orange is labeled "lead free")
Undo the screws on the side of the stepper component with A DIFFERENT SCREWDRIVER TO AVOID STRIPPING
The screwdriver will be smaller than the M3x6 fit
Gently extract after screw removal
flip the leftovers over and slide the peice of black plastic far forward to remove the screws holding the metal in place
Slide the disk tray back if you can not remove it completely and proceed to unscrew the final and 3rd screw.
Gently remove any clips to allow the only holder to be the rubber wheels to be holding it(circled in red)
Gently apply pressure to pull away from the main casing
Un-clip the clips seen in photo 2
To remove the pole that was in the picture before it was removed, push down on the spring with a screw at one end removed the tilt one end up and remove
To remove toothed gears push the clip inside the spire in the middle of the gear, and maintaining pressure on the clip pull away the gear
Apply the same technique as in picture 2 but with the clip in picture 3
