Einleitung
A multimedia LCD projector from Sony, the VPL-ES1.
This Teardown may help you fix/ replace many items that could possibly go wrong with this unit - Replacing the lamp, to changing the Automatic Lens Door and so on.
It's amazing just ho much they fit into these things- reminds me of what i like to call Chinese Tetris. Although Sony is a very Japanese Co.
-On to the fun-
Was du brauchst
The Front view, Side view w/ Power input, Audio in, Coax in, VGA in and VGA out. Along with Zoom and Focus Dials
The Bottom View
First we are going to remove the Lamp by removing the screw in the first image, and opening and removing the door to the lamp
Then we unscrew the two screws on the lamp. they do not completely disconnect from the lamp. So they will remain attached after unscrewing them.
Then lift up on Lamp Handle to remove Lamp from projector assmebly
At this point we will remove the six screws located on the underside of the unit.
These are the long screws in the second photo here
Flip the unit over carefully and pry the case off working around the edges. Take note there is a ribbon cable that runs from the outer control panel to the mainboard.
Pull ribbon cable from mainboard. Place top of unit to the side of your work area.
First Look at the Inside
Now you will remove all other connectors from the outer parts of the mainboard. as marked in the Red Rectangles. Gently, pull them out of their connection place.
There is one connector from the mainboard to the little blue board in the bottom righthand corner that is connected on the underside of the mainboard. Just disconnect this one from at the blue board.
You will find that the two connectors labeled in a yellow rectangle are not connected to anything leading me to believe that this mainboard may be used with other model projectors as well.
Remove the five screws marked in the red Circles from the mainboard.
In the Third image you will find the LCD Ribbon Cable on the Center of the Board. You will remove the three of the cables by gently pulling up on either side of the tiny brown connectors attching them to the board
Now to remove the mainboard. Gently pry outwards the Left side of the casing and lift the board up out of the Unit. Being carefull to watch the input connections near the side of the case.
Now the Mainboard has been removed
have a look at some of our main components. The LCD and Prism connected to the Lens as well as some of the cooling Channels.
You can opt to remove this little board from a fan shroud but i chose to leave it attached
I removed it to show you what it looks like anyway.
Remove screw marked in red
This appears to be something that holds the board up for some reason that is beyond me?
And a picture of it removed
Remove the two screws that run from the power supply to the lamp
Pull out the connector
There are three Screws to be removed from the fan shroud in this step
Remove Fan Shroud
Now lift up and remove the fan
To remove the side panel of the case- gently pry around the corners until removed
A look at the side and rear panel of the case removed
Now we Remove the 5 screws of the Mirror/LCD/Lens assembly
And from the left side lift up on the Projection assmebly to remove from the unit
Projection assembly removed
Next remove the fan Channel by unscrewing one screw as labeled in red circle
This piece i find rather interesting considering the job of the one fan is to route air particularly to the underside of the three LCD Screens for cooling
Now there will be a tiny circuit switch upright after removing the fan channel.
Remove simply by lifting out out placement niche
Now we are going to look at removing the Automatic Lens door/Cap and Zoom/Focus Dials
We must remove the Zoom/Focus Dials first in order to proceed. Remove the one screw as labeled in the red circle. and gently remove the two dials out together
Next to remove the screw holding the Autolens Cap to the rest of the unit.
Now you can remove the Autolens cap with motor attached( on the right)
The second image is just a view of what is left on the Unit from the left hand side.
This 3rd pic has another interesting Fan channel from the left underside of the Power supply to the Lamp assembly in two different chutes.
Now onto the LCD Assembly - The heart of this projector.
Shoot for the exhaust duct LUkE!
The underside of the LCD / Lens Assembly to show you the Cooling ducts leading up to the LCD panels. Neat huh?
The lens is removed by unscrewing the 4 screws located on the outer corners of the lens fixture.
New line.And a look at the lens by itself and it Zoom / Focus Ring Dials
A cool look inside the assembly minus the lens
To remove the LCD innards unscrew the two screws marked in RED circles
Now, if needed you can remove the LCD assembly / Prism from the rest of the unit by simply pulling it out gently
A shot of the LCD Assembly, Lens, Lamp and Mainboard.
Then a look at all of the Components. The Completed disassembly
4 Kommentare
Hi, Thanks for such a detailed teardown. Appreciated!
I have a Sony VPL-DW120 projector. Last time, when I just pressed the remote power on button, the projector made a pop or cracking sound. Afterwards no indicator light on the panel is seen and it's not powering on at all; changed power cables and input socket but in vain. Is there any fuse which needs to be replaced or my motherboard gone? Please advise.
Regards,
hey can i ask a quick question? i’ve got a broken microswitch to replace, the one that’s used when opening the shutter. it’s an AV4 4b but i can’t find these anywhere. do you know where i can get one or a good alternative??
dear sir i have an important question can you send a message on instagram to me my name viuna.company thanks
