Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
The Sony Ericsson s710a is a camera phone with all of the features expected of a phone in the mid '00's.
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony Ericsson s710a zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Remove the back cover by sliding it off.
    • Remove the back cover by sliding it off.
  2. Once the back cover is removed, pull out the battery using your finger as shown.
    • Once the back cover is removed, pull out the battery using your finger as shown.
  3. The battery can now be replaced if desired.
    • The battery can now be replaced if desired.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Remove the four 6mm screws behind the battery.
    • Remove the four 6mm screws behind the battery.
  5. Remove plastic piece near the base of the keypad. This will require prying it off with a plastic opening tool and breaking the seal with the glue. Unfortunately there is no way around this.
    • Remove plastic piece near the base of the keypad.
    • This will require prying it off with a plastic opening tool and breaking the seal with the glue. Unfortunately there is no way around this.
    • Then remove the two 6mm screws beneath the plastic cover with a Phillips head screw driver.
    • Now you are ready to remove the plastic back cover.
  6. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  7. Use the plastic opening tool to pry off the back cover of the phone. This will require a bit of careful work. You should start prying the back cover from the SD card slot.
    • Use the plastic opening tool to pry off the back cover of the phone. This will require a bit of careful work.
    • You should start prying the back cover from the SD card slot.
    • Alternate prying the back cover on each side until it pops off.
  8. Use the plastic opening tool to carefully pry out the circuit board once you have removed the back cover.
    • Use the plastic opening tool to carefully pry out the circuit board once you have removed the back cover.
  9. Remove the LCD cable connectors coming from through the hinge hole with a flat head screw driver.
    • Remove the LCD cable connectors coming from through the hinge hole with a flat head screw driver.
    • IMPORTANT: be sure to record which port each cable was in and the orientation they were plugged into each socket.
    • Now the two parts of the phone are separated.
  10. On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
    • On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
    • When you lift this off, you will need to disconnect the cables from the other side using the same method as in step 5.
    • Again, be sure to record which port each cable was in and the orientation they were plugged into each socket.
  11. Remove the plastic piece near the bottom of this side of the phone with the plastic opening tool. This will give you access to two additional screws. Remember you will have to break the glue seal, but that is alright.
    • Remove the plastic piece near the bottom of this side of the phone with the plastic opening tool. This will give you access to two additional screws.
    • Remember you will have to break the glue seal, but that is alright.
    • Remove the four visible 6mm screws and then remove the back cover.
  12. In order to remove the LCD screen, use the plastic opening tool to pry the plastic piece from the LCD. Perform this step carefully to avoid scratching the glass screen.
    • In order to remove the LCD screen, use the plastic opening tool to pry the plastic piece from the LCD.
    • Perform this step carefully to avoid scratching the glass screen.
  13. In this picture, you can see all of the parts in the non-camera side of the phone.
    • In this picture, you can see all of the parts in the non-camera side of the phone.
    • Interestingly, the four control buttons are all one piece
  14. This phone has an array of capabilities:
    • This phone has an array of capabilities:
    • Bluetooth
    • Megapixel Camera
    • MP3 capable
    • Messaging options
    • This photograph shows the final result of a complete teardown.
Alexander
75 Reputation
4 Anleitungen geschrieben
University of Maryland, Team 1-1, Calloway Fall 2011 Mitglied von University of Maryland, Team 1-1, Calloway Fall 2011
UMD-CALLOWAY-F11S1G1
3 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 3,872
