Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein PlayStation zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: Schritt 1, Bild 1 von 2 Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: Schritt 1, Bild 2 von 2
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    • Note: part number +BV 3X14
  2. Sony PlayStation SCPH-9002 Teardown: Schritt 2, Bild 1 von 1
    • Remove the top cover. It's very easy.
  3. Sony PlayStation SCPH-9002 Teardown: Schritt 3, Bild 1 von 1
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
    • Note: part number DEVICE OPTICAL KSM-440AEM
  4. Sony PlayStation SCPH-9002 Teardown: Schritt 4, Bild 1 von 2 Sony PlayStation SCPH-9002 Teardown: Schritt 4, Bild 2 von 2
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Sony PlayStation SCPH-9002 Teardown: Schritt 5, Bild 1 von 1
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Sony PlayStation SCPH-9002 Teardown: Schritt 6, Bild 1 von 1
    • Remove the four screws and the metal cover.
  7. Sony PlayStation SCPH-9002 Teardown: Schritt 7, Bild 1 von 2 Sony PlayStation SCPH-9002 Teardown: Schritt 7, Bild 2 von 2
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Sony PlayStation SCPH-9002 Teardown: Schritt 8, Bild 1 von 1
    • Once the screws are removed, remove the power supply.
  9. Sony PlayStation SCPH-9002 Teardown: Schritt 9, Bild 1 von 1
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Sony PlayStation SCPH-9002 Teardown: Schritt 10, Bild 1 von 1
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
194 Reputation
1 Anleitung geschrieben
1 Kommentar zur Anleitung
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 36
Letzte 30 Tage: 167
Insgesamt: 31,091
