Einleitung
I have a PlayStation 1, and i have decided to make a new teardown of it.
I'm spanish, so my english is a bit poor, and sorry for the mistakes made in this teardown.
Without further delay, we start.
Was du brauchst
Here's the PS1.
Turn the PS1 over and remove the six screws.
Note: part number +BV 3X14
Disconnect both CD-ROM connectors.
CD connector one and the socket it connects to.
CD connector two and the socket it connects to.
Note: part number DEVICE OPTICAL KSM-440AEM
Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
Detach both cables. They go to the power supply and to the memory cards and controller connectors.
Now you have the motherboard!
And the power supply.
Remove the four screws from the motherboard and the power supply.
Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
Now, you have all your PlayStation 1 parts!
Main Board
Lower Casing
EMI Shield
Power Supply
Disk Reader
Memory Card/ Controller Mechanism
