Einleitung
Sony Desktop Computer-
The Proprietary Force that is my Pentium 4 PC.
At the time it was released it was a very half decent computer. Sony Deemed this model a Digital Studio because of all its Audio and Video inputs and outputs. It has Video inputs on the front panel and optical audio and DVI Video outs on the rear. There is also a Mpeg Decoder/Encoder board for use with recording television via Cable Conection and an infrared remote to control certain programs with (Giga Pocket). I have Upgraded a few things including adding another Hard Drive and maxxed the Memory to a stunning 1.5gb.
If you use this information to upgrade this PC, take in mind that it may be easier to skip some steps say if your going to install new memory or another hard drive as I've done.
So here it is, The Systematic Disassembly
To Really be Blown Away By the Magic - Watch in Slideshow,
-Link Below-
Was du brauchst
Remove the side panel by unlocking the retaining clips on the rear of the PC and sliding the panel off.
You may want to put the PC on its side at this time.
Remove the Power Cables from the Hard Drive(s). These are Molex Connectors
Do this by pulling the clip on either side - May require a little force
Remove power to the motherboard by finding the 20 pin Connector and disconnecting it.
Also remove the 4 pin P3 Connector and the brown mini connection next to it.
Now remove power from the two Cd/DVD Drives- these are the same Molex connectors as the Hard Drives.
Remove Power Cable from the Floppy Drive. - this is known as a mini connector. As shown boxed in Red
Now That all Power connectors are un-attached, we will remove the power supply.
Unscrew four screws (labeled in yellow Circles) Then lift power supply out of Case.
We can now remove the Data Cables- These are called IDE Cables
They are removed by simply pulling them out.
First from the the Hard Drives then from the Floppy and Disk Drives
The two Hard Drives have their own seperate encasement
Lift up on the Latch as shown
Remove the Hard Drive assembly
Remove all Connections from Front Panel assembly as shown in image.
Unscrew the one screw holding the front panel connectors to the case.
Pull Front panel connector assembly out of case
On this Panel is an S-Video in, Red, White and Yellow RCA inputs an Ilink S400 port and 2 USB Ports
To Remove the top of the case, unclip the retaining clips as marked
Pull top from case
Next to remove the Front Panel of the Case.
There are retaining clips as with the top of the case, Unclip them and remove the Front Panel.
Remove the Sony Memory card reader by unplugging it from the motherboard and unscrewing the single screw (in red). Then simply slide it out of it's little niche
Next we will remove both of the Optical Disk Drives.
Pull up on latch, releasing the lock enabling you to pull up on drive box assembly and lift out of case
Removing of the Optical Drive Bay.
Then a quick look at the interior of the PC So Far
Now onto the Power button / Light panel in the front of the PC.
Unscrew single screw at front of PC to remove . Unattach connector on front side and pull cable through hole in Case.
Now we will remove our AGP Graphics card by first removing the screw from the top left holding it secure to the card slot.(in Red)
Before pulling the card out of it's placement you must unlatch this little plastic lever to release. (Second image in RED)
Next is the PCI Mpeg Decoder Board. Remove the Cable that connects from the motherboard to the card.
Unscrew and remove the Mpeg/Video In Board.
And remove the Last PCI Card by unscrewing the single Screw. This card is a PCI -Serial Port adapter.
In order to remove the case fan, First disconnect its power cable from the Motherboard.
Then unlatch the Four Retaining clips to release the fan- and Remove.
Now to remove the Motherboard-Remove Labeled Screws in image
Be Careful to keap mind of the connection ports on the rear of the Motherboard while removing. So your going to want to lift it out first on the right side then the side with the ports.
Now lift the Motherboard out of the Case
Disconnect the PC fan from the motherboard, Unscrew the four screws and remove.
Unlatch the Memory Slots on either side.
Remove Memory Dimms by lifting out of slot
In order to remove heatsink, apply pressure to the far side and pull out of latch on near side (Use Both hands).
After Releasing clips lift up and remove heatsink.
This particular Setup is called a Pin Grid Array (PGA)
In order to remove the Processor, lift the light brown latch out and up (as shown)
Careful, the top of the processor also has thermal paste on it.
A look at the Processor topside and underside.
This Particualr Intel Chip is a 2.53GHZ Pentium 4
I am going to clean the thermal paste off of the Processor and the heatsink and add a new application. This is not particularly needed but in this case i felt i would.
Ein Kommentar
Any videos how to put it all back together now. I took mine apart. Need help putting it back together
