Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony Walkman WM-4 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: Schritt 1, Bild 1 von 2 Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: Schritt 1, Bild 2 von 2
    • Flip the Sony Walkman so that its rear side faces you.
    • Use a screwdriver to remove the two screws from the surface of the Walkman.
    • Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
    • Remove the batteries from the Walkman.
  2. Sony Walkman WM-4 Teardown: Schritt 2, Bild 1 von 2 Sony Walkman WM-4 Teardown: Schritt 2, Bild 2 von 2
    • Turn over your Walkman and gently press the cover to open the cassette holder.
    • When the cassette holder is opened, you can see two more screws.
    • Using a screwdriver, remove the two screws.
  3. Sony Walkman WM-4 Teardown: Schritt 3, Bild 1 von 2 Sony Walkman WM-4 Teardown: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman.
    • Be careful so you dont break the tabs!
    • Once the Walkman is opened, you can troubleshoot for any issues, remove the old wires and attach new ones, or even reassemble the Walkman.
lenzo
125 Reputation
1 Anleitung geschrieben
1 Kommentar zur Anleitung
Drive belt trashed any ideas where to get one?
nz-tiger - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 51
Insgesamt: 16,908
