Einleitung
My first Handheld Device. A Sony FM/AM Tape Cassette Walkman. It has Digital Controls for the Radio /Alarm Clock on the front and Old school cassette controls on the side. Found it again in a Logitech Tape Case with a Live Medski, Martin and Wood show from 99 in it. Runs on 2 AA batteries. This Walkman was my first Portbale device and I've kept it through all these years. Tis officially my first breakdown on IFIXIT
Was du brauchst
Start with removing the screw on the Underside. The screw on the Backside next. Then the two on the reverse side of the tape controls.
New line.
Take care not to jostle the Switches on the top of the unit while removing case. So now we have removed the underside casing from the device.
Find Ribbon Cable that connects to the board. Carefully Pry open either side of connector as shown, then remove ribbon cable from board.
Find Door Spring and remove carefully. Then find and pry off (on either side) glued on bumpers- These limit the distance the door hinge can travel in order to be pulled off---
Now gently pry the door hinges on either side off of their pivot point, and remove the front door from the assembly
There is your front mounted control board! It is attached to what appears to be a speaker i'm guessing. Possibly for the alarm clock. I found that to be interesting, the little speaker thing. Anyways , thats it.
5 Kommentare zur Anleitung
Please provide more info on how to put the spring back together again. I have a WM-FX435.
Hi, the casette operation has failed. Now I try to check. Really I do not the reason. Any suggestion?
Exactly what I needed to change the drive belts, which turned out to be super easy using these directions and excellent pictures. Thank you so much!
