Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony Xperia Z3 Compact zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Sony Xperia Z3 Compact Teardown, Remove back cover: Schritt 1, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove back cover: Schritt 1, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove back cover: Schritt 1, Bild 3 von 3
    • Apply heat to weaken adhesive. If using a heat gun, use a higher temperature such as 150℃ for a minute because the waterproof adhesive sticker is strong.
    • Place the suction cup and pull to create a gap. Insert a guitar pick to cut the sticker and remove the back cover.
  2. Sony Xperia Z3 Compact Teardown, Remove back frame: Schritt 2, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove back frame: Schritt 2, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove back frame: Schritt 2, Bild 3 von 3
    • Sony Xperia Z3 Compact NFC is stuck to the battery and connected with the motherboard by metal springs, so free the connector at first.
    • Remove all five screws from the rear frame.
    • Starting from the left corner, pry up the rear frame. There is no adhesive, so it's not difficult.
  3. Sony Xperia Z3 Compact Teardown, Remove rear camera: Schritt 3, Bild 1 von 2 Sony Xperia Z3 Compact Teardown, Remove rear camera: Schritt 3, Bild 2 von 2
    • Remove rear camera securing bracket.
  4. Sony Xperia Z3 Compact Teardown: Schritt 4, Bild 1 von 3 Sony Xperia Z3 Compact Teardown: Schritt 4, Bild 2 von 3 Sony Xperia Z3 Compact Teardown: Schritt 4, Bild 3 von 3
    • Release rear camera connector and take it away easily.
  5. Sony Xperia Z3 Compact Teardown, Remove motherboard: Schritt 5, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove motherboard: Schritt 5, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove motherboard: Schritt 5, Bild 3 von 3
    • Release all the connectors connecting with motherboard including the LCD screen connector and headphone jack connector. Undo the only screw on the motherboard.
  6. Sony Xperia Z3 Compact Teardown: Schritt 6, Bild 1 von 2 Sony Xperia Z3 Compact Teardown: Schritt 6, Bild 2 von 2
    • Pry up the motherboard from left side but avoid side buttons. It should come off easily since there is no adhesive sticker underneath.
  7. Sony Xperia Z3 Compact Teardown: Schritt 7, Bild 1 von 3 Sony Xperia Z3 Compact Teardown: Schritt 7, Bild 2 von 3 Sony Xperia Z3 Compact Teardown: Schritt 7, Bild 3 von 3
    • Before removing the whole motherboard assembly, we need to get the motor vibration free from it's sticker. It's not strong and easy to handle.
    • There are front camera, main flex, signal cable and battery come with the motherboard.
  8. Sony Xperia Z3 Compact Teardown, Remove front camera: Schritt 8, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove front camera: Schritt 8, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove front camera: Schritt 8, Bild 3 von 3
    • Release the connector and remove the camera easily.
  9. Sony Xperia Z3 Compact Teardown, Remove main flex: Schritt 9, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove main flex: Schritt 9, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove main flex: Schritt 9, Bild 3 von 3
    • The side buttons are fastened by clasps, which are easily freed. Release the connector and remove the main flex.
    • The main flex is smaller than other Xperia Z series devices.
  10. Sony Xperia Z3 Compact Teardown, Remove signal cable: Schritt 10, Bild 1 von 2 Sony Xperia Z3 Compact Teardown, Remove signal cable: Schritt 10, Bild 2 von 2
    • Remove signal cable.
  11. Sony Xperia Z3 Compact Teardown, Remove battery: Schritt 11, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove battery: Schritt 11, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove battery: Schritt 11, Bild 3 von 3
    • Detach the connector to the motherboard.
    • Next pull firmly on the two small black tabs protruding from underneath the battery. This stretches the adhesive strip and separates it from the battery and the motherboard.
    • CAUTION: This strip is easily ripped when under tension.
    • If it does rip then a sharp flat piece of metal or a knife should be used to cut through the remaining strip.
    • WARNING: This adhesive is very strong. Too much effort, prying or careless cutting may break the motherboard. The torn cover of the battery in the picture shows how strong the sticker is.
  12. Sony Xperia Z3 Compact Teardown, Remove headphone jack: Schritt 12, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove headphone jack: Schritt 12, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove headphone jack: Schritt 12, Bild 3 von 3
    • Cut the adhesive under the flex and between headphone jack and midframe. And then pry up the sensors gently and remove the assembly finally.
  13. Sony Xperia Z3 Compact Teardown, Remove loudspeaker: Schritt 13, Bild 1 von 1
    • It's easy. Pry up and take it away.
  14. Sony Xperia Z3 Compact Teardown, Remove LCD screen: Schritt 14, Bild 1 von 3 Sony Xperia Z3 Compact Teardown, Remove LCD screen: Schritt 14, Bild 2 von 3 Sony Xperia Z3 Compact Teardown, Remove LCD screen: Schritt 14, Bild 3 von 3
    • Heat, cut the sticker and remove it. Notice where the earpiece is and be careful not to separate them when using the guitar pick. It's easy to break the earpiece.
  15. Sony Xperia Z3 Compact Teardown, Remove earpiece: Schritt 15, Bild 1 von 2 Sony Xperia Z3 Compact Teardown, Remove earpiece: Schritt 15, Bild 2 von 2
    • The earpiece is affixed to the touch panel directly, which is why it not recommended to separate it when disassembling the screen.
  16. Sony Xperia Z3 Compact Teardown: Schritt 16, Bild 1 von 1
    • Done.
Sophia
43.810 Reputation
62 Anleitungen geschrieben
20 Kommentare
I LOVE your work Sophia!
PLEASE also do a TOP VIEW shot as it would help me beter to look straight down. With or without tweezers is fine. JUST LOOKING Straight down would be better for so many reasons.
YOU ROCK!
P.S. Or just do a single TOP VIEW at the END like this one from Dillon ! Pretty Please!
T-Mobile Huawei Prism U8651T Teardown
Top View - Antwort
Awesome! Very neat, carefully explained with tips. Keep up the good work, you might save so many amateurs/experts & their devices!!!
Mahammad Suhail - Antwort
May I know, what is the size of the 5 screws used on the back frame?
shariman91 - Antwort
Great work, much appreciated!
A GENIOUS screwed my Z3C and now im in the process of fixing it up. Clarifies alot. Just a couple of questions, whats the best way to convey them to you?
Atif Rana - Antwort
can u guys tell me where i can find rear camera securing bracket cause something happend when i remove it and now my wireless range is a 1 step far from router or i canot connetc to the router ...
Niklaus Yusein - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 56
Insgesamt: 100,367
