Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
Have a look at the inside of Sony Xperia Z3 Dual and let you know where is component when need repair.
Witrigs is specialized in cellphone accessories and kinds of replacement guide.
Remove two SIM card trays.
Heat the back cover to soften the adhesive sticker.
Place the suction cup and to open a gap from top side.
Insert the guitar pick into the opening gap.
Slide the guitar pick to cut the adhesive sticker. Attention: when deal with the left side, the guitar pick would better go as the direction of the mark.
Remove that blocker beside the earpiece speaker at first.
And then you can pry up the earpiece speaker and remove it.
Pry to turn the flex cover on the earphone jack. But it's a part of the earphone jack assembly.
Cut the adhesive sticker between the earphone jack and midframe and remove the assembly.
Remove loudspeaker assembly securing bracket. And there is no any adhesive.
Pry up and remove the loudspeaker assembly. No adhesive, too.
9 Kommentare
Can you put it back together?
I dropped mine so I just want to take the battery out is it possibly to take it and then put it back in
hi.after changing my xperia z3 dual lcd 3 times.i hade a fluctuating and very week 3g and 4g signal.plz tell me where is the antenna located.i know that there is a flex and a board and antenna cover.what should i change.thanx
That's not a complete teardown. I would like to see the onboard chips and info's.
