Zum Hauptinhalt wechseln
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony Xperia Z4 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Remove back cover. Remove back cover.
    • Remove back cover.
  2. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  3. Release all the connectors on board and remove the screws there. Release all the connectors on board and remove the screws there.
    • Release all the connectors on board and remove the screws there.
  4. Remove that small securing bracket. Remove that small securing bracket.
    • Remove that small securing bracket.
  5. Remove rear camera and front camera. Remove rear camera and front camera. Remove rear camera and front camera.
    • Remove rear camera and front camera.
  6. Remove motherboard. Remove motherboard.
    • Remove motherboard.
  7. Remove sensor flex. Remove sensor flex. Remove sensor flex.
    • Remove sensor flex.
  8. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack.
    • Remove two pieces of cover brackets on the audio jack.
  9. Cut the adhesive on the top of the audio jack and remove the audio jack assembly. Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
    • Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
  10. Remove signal cable.
    • Remove signal cable.
  11. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it.
    • Release connectors connecting on the antenna logic board and finally remove it.
  12. Release LCD connector there and loosen the bottom of the whole flex. Release LCD connector there and loosen the bottom of the whole flex.
    • Release LCD connector there and loosen the bottom of the whole flex.
  13. Remove main flex. Remove main flex. Remove main flex.
    • Remove main flex.
  14. Remove loudspeaker securing bracket. Remove loudspeaker securing bracket.
    • Remove loudspeaker securing bracket.
  15. Remove loudspeaker hidden under the flex. Remove loudspeaker hidden under the flex.
    • Remove loudspeaker hidden under the flex.
  16. Push the USB port out of the slot. Push the USB port out of the slot.
    • Push the USB port out of the slot.
  17. Remove USB charging flex assembly. Remove USB charging flex assembly.
    • Remove USB charging flex assembly.
  18. Remove earpiece speaker. Remove earpiece speaker.
    • Remove earpiece speaker.
  19. Remove the metal bracket covering on the screen flex. Remove the metal bracket covering on the screen flex.
    • Remove the metal bracket covering on the screen flex.
  20. Remove LCD screen carefully. Remove LCD screen carefully. Remove LCD screen carefully.
    • Remove LCD screen carefully.
  21. Done.
    • Done.
Sophia
42.291 Reputation
62 Anleitungen geschrieben
Is it possible to replace the nylon corners? I've heard it was possible in the previous xperia z devices like z2 and z3. Unfortunately I couldn't find the replacement corners for z3+ or z4 anywhere. Anyone has any idea about it?
Sanket - Antwort
Late answer, but it seems like there’s replacement parts for the corners now. I don’t know how to replace them, though.
Farie Indriawan -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 6
Letzten 7 Tage: 65
Letzten 30 Tage: 409
Insgesamt: 28,041
