Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony Xperia Z4 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Remove back cover. Remove back cover.
    • Remove back cover.
    How much heat needed to melting down the back cover adhesive…
    Aspar Riansyah - Antwort
    it is no need to heat too much.
    KK0902 -
  2. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  3. Release all the connectors on board and remove the screws there. Release all the connectors on board and remove the screws there.
    • Release all the connectors on board and remove the screws there.
  4. Remove that small securing bracket. Remove that small securing bracket.
    • Remove that small securing bracket.
  5. Remove rear camera and front camera. Remove rear camera and front camera. Remove rear camera and front camera.
    • Remove rear camera and front camera.
  6. Remove motherboard. Remove motherboard.
    • Remove motherboard.
  7. Remove sensor flex. Remove sensor flex. Remove sensor flex.
    • Remove sensor flex.
  8. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  9. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack.
    • Remove two pieces of cover brackets on the audio jack.
  10. Cut the adhesive on the top of the audio jack and remove the audio jack assembly. Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
    • Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
  11. Remove signal cable.
    • Remove signal cable.
  12. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it.
    • Release connectors connecting on the antenna logic board and finally remove it.
  13. Release LCD connector there and loosen the bottom of the whole flex. Release LCD connector there and loosen the bottom of the whole flex.
    • Release LCD connector there and loosen the bottom of the whole flex.
  14. Remove main flex. Remove main flex. Remove main flex.
    • Remove main flex.
  15. Remove loudspeaker securing bracket. Remove loudspeaker securing bracket.
    • Remove loudspeaker securing bracket.
  16. Remove loudspeaker hidden under the flex. Remove loudspeaker hidden under the flex.
    • Remove loudspeaker hidden under the flex.
  17. Push the USB port out of the slot. Push the USB port out of the slot.
    • Push the USB port out of the slot.
  18. Remove USB charging flex assembly. Remove USB charging flex assembly.
    • Remove USB charging flex assembly.
  19. Remove earpiece speaker. Remove earpiece speaker.
    • Remove earpiece speaker.
  20. Remove the metal bracket covering on the screen flex. Remove the metal bracket covering on the screen flex.
    • Remove the metal bracket covering on the screen flex.
  21. Remove LCD screen carefully. Remove LCD screen carefully. Remove LCD screen carefully.
    • Remove LCD screen carefully.
    Gerade so ein schwieriger Schritt, wie das Entfernen des Displays, bei dem auch echt viel schief gehen kann, sollte ruhig etwas detaillierter beschrieben werden. Die Mühe ist man der Community echt schuldig.
    Davon mal abgesehen ist das Bildmaterial echt gut gelungen!
    Gerdi - Antwort
  22. Done.
    • Done.
Sophia
43.006 Reputation
62 Anleitungen geschrieben
Is it possible to replace the nylon corners? I've heard it was possible in the previous xperia z devices like z2 and z3. Unfortunately I couldn't find the replacement corners for z3+ or z4 anywhere. Anyone has any idea about it?
Sanket - Antwort
Late answer, but it seems like there’s replacement parts for the corners now. I don’t know how to replace them, though.
Farie Indriawan -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 14
Letzten 7 Tage: 64
Letzten 30 Tage: 230
Insgesamt: 30,877
