Was du brauchst
Einführungsvideo
Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
Release connectors connecting on the antenna logic board and finally remove it.
Remove LCD screen carefully.
2 Kommentare
Is it possible to replace the nylon corners? I've heard it was possible in the previous xperia z devices like z2 and z3. Unfortunately I couldn't find the replacement corners for z3+ or z4 anywhere. Anyone has any idea about it?
Late answer, but it seems like there’s replacement parts for the corners now. I don’t know how to replace them, though.
How much heat needed to melting down the back cover adhesive…
Aspar Riansyah - Antwort
it is no need to heat too much.
Snowflake -
