Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony Xperia Z5 Compact zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Sony Xperia Z5C Teardown, Sony Xperia Z5C Teardown: Schritt 1, Bild 1 von 2 Sony Xperia Z5C Teardown, Sony Xperia Z5C Teardown: Schritt 1, Bild 2 von 2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5C Teardown: Schritt 2, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 2, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 2, Bild 3 von 3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5C Teardown: Schritt 3, Bild 1 von 2 Sony Xperia Z5C Teardown: Schritt 3, Bild 2 von 2
    • Twist off 10 Phillips screws all.
    • Loosen NFC clip and flashlight clip.
    Could you give a bit more detail on how to carefully "loosen" the NFC chip....
    maybe it's just me bein dumb but he seems like it'll snap if I contine like this
    Mick “the silent one” Meijdam - Antwort
  4. Sony Xperia Z5C Teardown: Schritt 4, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 4, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 4, Bild 3 von 3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5C Teardown: Schritt 5, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 5, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 5, Bild 3 von 3
    • Remove front camera.
  6. Sony Xperia Z5C Teardown: Schritt 6, Bild 1 von 2 Sony Xperia Z5C Teardown: Schritt 6, Bild 2 von 2
    • Remove earpiece.
    I don’t think you should just pull it off. With mine it looks like it breaks the speaker when you do this. There are two very fine wires below the metal box, that seem to connect to some kind of speaker coil that is embedded in plastic that is glued to the shell.
    Hans Wuast - Antwort
  7. Sony Xperia Z5C Teardown: Schritt 7, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 7, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 7, Bild 3 von 3
    • Remove rear camera.
  8. Sony Xperia Z5C Teardown: Schritt 8, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 8, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 8, Bild 3 von 3
    • Remove loudspeaker.
  9. Sony Xperia Z5C Teardown: Schritt 9, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 9, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 9, Bild 3 von 3
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
    • The motherboard may be attached to the case by a sticky pad near the charging connector. This can be dislodged by very carefully rotating the motherboard side to side, checking that the flex connectors aren't being stretched.
  10. Sony Xperia Z5C Teardown: Schritt 10, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 10, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 10, Bild 3 von 3
    • Push audio jack out of the slot, no adhesive underneath.
    • Release LCD flex connector and main flex connector by flipping up the white locking tab of the connector base.
    • Separate motherboard assembly from middle housing.
  11. Sony Xperia Z5C Teardown: Schritt 11, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 11, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 11, Bild 3 von 3
    • Remove audio jack flex by flipping up the white locking tab of the connector base.
    yes hello do you have a 32 gb motherboard for sale??
    if no do you knowe where can I buy it please get back too me
    leon - Antwort
  12. Sony Xperia Z5C Teardown: Schritt 12, Bild 1 von 2 Sony Xperia Z5C Teardown: Schritt 12, Bild 2 von 2
    • Remove flashlight flex by flipping up the white locking tab of the connector base.
  13. Sony Xperia Z5C Teardown: Schritt 13, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 13, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 13, Bild 3 von 3
    • Remove microphone flex by flipping up the white locking tab of the connector base.
  14. Sony Xperia Z5C Teardown: Schritt 14, Bild 1 von 2 Sony Xperia Z5C Teardown: Schritt 14, Bild 2 von 2
    • Take away NFC antenna on battery.
  15. Sony Xperia Z5C Teardown: Schritt 15, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 15, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 15, Bild 3 von 3
    • Release battery connector and pull off adhesive tapes underneath.
    • Pry up and remove battery.
    lol... pry up and remove battery! You fail to mention the industrial factory stickers that are securing the battery to the motherboard. These two bad boys are seriously sticky and cannot just be pried up. If you look at the mobo pic below you'll see 5 lines, the two stickers are placed between the top two lines and across the middle line where the three lines are (just to guide you). First time I tried I struggled a lot! What I did on the next few was to heat up the battery with a hair dryer so that the stickers became soft, and then I pried up the battery very carefully, a bit at a time, using small pieces of soft plastic (so as not to damage the mobo), and re-heating when it got tough again. Battery removal will take at least 10 minutes. Just be careful and take time as the mobo is quite delicate. (note, if you are just changing the battery, you don't need to remove half of what's described in this teardown. Also make sure you disconnect the mobo battery terminal before removal). Hope this helps!
    Sony Xperia - Antwort
  16. Sony Xperia Z5C Teardown: Schritt 16, Bild 1 von 2 Sony Xperia Z5C Teardown: Schritt 16, Bild 2 von 2
    • Here is the motherboard only.
  17. Sony Xperia Z5C Teardown: Schritt 17, Bild 1 von 2 Sony Xperia Z5C Teardown: Schritt 17, Bild 2 von 2
    • Remove charging port flex.
  18. Sony Xperia Z5C Teardown: Schritt 18, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 18, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 18, Bild 3 von 3
    • Loosen adhesive underneath vibration motor.
    • Loosen side button assembly. There is fingerprint scanner here, be careful.
    • Loosen noise canceling microphone.
  19. Sony Xperia Z5C Teardown: Schritt 19, Bild 1 von 2 Sony Xperia Z5C Teardown: Schritt 19, Bild 2 von 2
    • Loosen all adhesive underneath side button flex assembly.
    • Here is side button flex assembly. It’s integrated by vibration motor, side button connector, fingerprint scanner connector and noise-canceling mic.
  20. Sony Xperia Z5C Teardown: Schritt 20, Bild 1 von 3 Sony Xperia Z5C Teardown: Schritt 20, Bild 2 von 3 Sony Xperia Z5C Teardown: Schritt 20, Bild 3 von 3
    • The sticker underneath LCD assembly is a little bit strong, so use heat gun to soften it for a few minutes.
    • Remove LCD with digitizer assembly carefully.
  21. Sony Xperia Z5C Teardown: Schritt 21, Bild 1 von 1
    • Done.
Witrigs
69.454 Reputation
378 Anleitungen geschrieben
6 Kommentare
The Rear Camers is what rattles if tapped on the corners.
Shan Memon - Antwort
Hi! How could I get more info on the fingerprint scanner? Can it be identified?
Ivan - Antwort
Hi iv broken one of the clips on the board that attaches the LCD screen can you get replacement?
Becky - Antwort
My Z5 Compact frame is broken near to the power button (the color part).
Is there any way to buy just the frame?
alexandren - Antwort
What is the black layer behind the LCD (which can be seen through squares left for SoC heatsinks). Is it a graphite cooling shield just like it is in XZ Premium?
Guven Nalbant - Antwort
Hi! I have a Z5 compact with the following issues:
• gyroscope not working
• accelerometer not working
• sim reader not working (with the sim inserted it does not get recognised)
• compass not working (tested through G Maps & GPS Test)
Regarding the sim reader, although complicated and risky, it can be replaced, but when it comes to all the other problems I can’t think of any decent solution.
Do you have any idea about where on the motherboard & what type exactly are the chips responsible for the gyro, accelerometer and compass?
P.S. Buying a new motherboard or another phone is not an option. As I cannot benefit from the warranty of the phone due to the strict location conditions enforced by Sony’s Customer Support program I am looking forward towards improving my soldering skills with this (once) wonderful piece of technology :D
George - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 57
Insgesamt: 36,917
