Zum Hauptinhalt wechseln
Was du brauchst
Videoanleitungen
Dieser Teardown ist keine Reparaturanleitung. Um dein Super Nintendo Classic Edition zu reparieren, verwende unsere Fehlerbehebungsseite.
5 Kommentare
at 00:37, it says HDMI. HOW DOES THAT THING HAVE HDMI?
Aiden - Antwort
pics are > video, tho ideally there would be both, but for heaven’s sake, if you’re only gonna have one or the other, stick to pics!!!!!!!
Firstname Lastname - Antwort
So a while ago I decided to take my SNES classic apart for whatever reason, and when I came to turn it back on, the power led was not working and the reset button was not working. I think I’ve found that the problem is within the board itself, so I am unsure if I could buy that smaller board for the console somewhere else. I’ve tried cleaning it with isopropyl alcohol and to no avail. Thanks for the help.
Nintendo Gaming - Antwort
So I recently opened mine up and cleaned it up with isopropyl. After doing this it turns on but nothing appears on the Television, I finally got it to work but anytime the console is moved, even the smallest amount the display flickers. Is this a short in the boar? Is there away to fix it?
Thomas Sullivan - Antwort
yes you can fix it when you opened it and cleaned it you may have put something out of place or you knocked it out of place go back in to it and make sure its all good
tostypinapple -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 57
Insgesamt: 13,429
