Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Super Nintendo Entertainment System Controller zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Super Nintendo Entertainment System Controller Teardown, Super Nintendo Entertainment System Controller Teardown: Schritt 1, Bild 1 von 1
    • It's your classic Super Nintendo controller.
    • Notably, it's a wired controller (same as most of the controllers of the era), and has a very simple layout.
    • The design is often called a "dogbone", due to the shape of the lower part.
  2. Super Nintendo Entertainment System Controller Teardown: Schritt 2, Bild 1 von 1
    • Nintendo, unlike the Control Deck counterpart, did not use custom screws in the controller, therefore it's very easy to open and clean.
    • We remove the 5 Phillips screws on the back of the controller.
  3. Super Nintendo Entertainment System Controller Teardown: Schritt 3, Bild 1 von 2 Super Nintendo Entertainment System Controller Teardown: Schritt 3, Bild 2 von 2
    • Open... the... controller.
  4. Super Nintendo Entertainment System Controller Teardown: Schritt 4, Bild 1 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 4, Bild 2 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 4, Bild 3 von 3
    • There are two metal rods that we have to take care of before removing the rest, otherwise they might get lost.
    • We remove the two shoulder buttons.
  5. Super Nintendo Entertainment System Controller Teardown: Schritt 5, Bild 1 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 5, Bild 2 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 5, Bild 3 von 3
    • Now we can get onto the board! We first remove the cable from the slack poles.
    • After that, it's only a matter of lifting the board out.
  6. Super Nintendo Entertainment System Controller Teardown: Schritt 6, Bild 1 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 6, Bild 2 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 6, Bild 3 von 3
    • Onto the rubber pads that represent the buttons, we'll have to remove those too.
    • Many of these older controllers might have delicate rubber pads, they should be handled carefully.
  7. Super Nintendo Entertainment System Controller Teardown: Schritt 7, Bild 1 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 7, Bild 2 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 7, Bild 3 von 3
    • Inching closer, we get to the shoulder button's rubber pads.
    • We can finally remove the remaining plastic buttons from the D-Pad and face button areas.
  8. Super Nintendo Entertainment System Controller Teardown: Schritt 8, Bild 1 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 8, Bild 2 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 8, Bild 3 von 3
    • The board itself has the controller cable attached, we can remove that too.
    • Not all controllers have a removable cable. Some models, such as the SNS-102, have soldered-on cables.
    • We make sure to pull away from the connector, and not up! It might be a little difficult depending on how long it's been attached.
  9. Super Nintendo Entertainment System Controller Teardown: Schritt 9, Bild 1 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 9, Bild 2 von 3 Super Nintendo Entertainment System Controller Teardown: Schritt 9, Bild 3 von 3
    • The SNES Controller board features a number of pads as well as a chip.
    • The chip on the board is a 12-bit shift register, used to multiplex all the button signals on the controller into a more budget-friendly connector.
  10. Super Nintendo Entertainment System Controller Teardown: Schritt 10, Bild 1 von 1
    • Finally, we can see all the innards that make this little controller work.
    • Maybe we should play a few rounds of Super Mario World...
Foxlet
601 Reputation
3 Anleitungen geschrieben
2 Kommentare
What is the repair ability score ?
logan - Antwort
what size screws are used?
Elizabeth Ziriada - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 56
Letzte 30 Tage: 219
Insgesamt: 14,705
