Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Texas Instruments TI BA II Plus zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Texas Instruments TI BA II Plus Teardown, Texas Instruments TI BA II Plus Teardown: Schritt 1, Bild 1 von 1
    • The BA II Plus Professional calculator.
  2. Texas Instruments TI BA II Plus Teardown: Schritt 2, Bild 1 von 1
    • Remove the battery cover by sliding it out.
  3. Texas Instruments TI BA II Plus Teardown: Schritt 3, Bild 1 von 1
    • Firstly on the back cover, remove the small sticky soft cushioning material covering the recess with the screws in it. 4 of them in total. Unscrew them.
  4. Texas Instruments TI BA II Plus Teardown: Schritt 4, Bild 1 von 1
    • Use a flathead screwdriver to gently part the bottom and top cover at the hinge on the top.
  5. Texas Instruments TI BA II Plus Teardown: Schritt 5, Bild 1 von 1
    • Removing the back cover to reveal the foil, unscrew the 4 screws holding the foil and 4 other holding the printed circuit board to the front cover.
  6. Texas Instruments TI BA II Plus Teardown: Schritt 6, Bild 1 von 1
    • Remove the foil. Ensure all screws are off.
  7. Texas Instruments TI BA II Plus Teardown: Schritt 7, Bild 1 von 1
    • This must separate the front cover from the board. Remove the board and turn it over to view the front side with a soft black cushion cover over a smooth shinny mesh.
  8. Texas Instruments TI BA II Plus Teardown: Schritt 8, Bild 1 von 1
    • The keys should fall out of the front cover when you turn it over as well. Thats it!!!
VSP
101 Reputation
1 Anleitung geschrieben
4 Kommentare
Well, my TI BA II plus has a broken LCD screen which according to the customer care is not covered under the warranty. Is it possible to find a replacement LCD to replace the broken one in the calculator.
Thanks
VSP - Antwort
My calculated get in water, now its not working is there any way to repair it.
ankur - Antwort
Did it stopped working immediately ? Also what did u do then
Akshat S Gupta -
This is a terrific service that you are providing. It makes fixing thing so much easier. Thank you.
ROB LYTLE - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 9,279
