Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Texas Instruments TI-82 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Texas Instruments TI-82 Teardown, Texas Instruments TI-82 Teardown: Schritt 1, Bild 1 von 1
    • The calculator comes with a matching protective shield which slides down over the front; when the calculator is in use, you can slide it over the back. This is a nice touch, as it makes the cover much more difficult to lose.
    Frag FixBot
    Kommentar hinzufügen
  2. Texas Instruments TI-82 Teardown: Schritt 2, Bild 1 von 3 Texas Instruments TI-82 Teardown: Schritt 2, Bild 2 von 3 Texas Instruments TI-82 Teardown: Schritt 2, Bild 3 von 3
    • Flip the device over to access the battery cover.
    • Using a spudger, pry the release tab down and then pull the battery door up and off the calculator.
    • Remove:
    • 2 7.2mm Phillips #0 screws
    • 1 15.3mm Phillips #0 screw, and a battery retaining clip.
    • The CR1616 coin cell battery preserves settings and programs in memory while the main batteries are being changed.
    Frag FixBot
  3. Texas Instruments TI-82 Teardown: Schritt 3, Bild 1 von 1
    • Insert a spudger into the seam between the two halves of the case, and pry it apart.
    • Watch out for corrosion in older calculators around the battery terminals -- this is why you should never leave batteries in electronics for extended periods of time.
    Frag FixBot
  4. Texas Instruments TI-82 Teardown: Schritt 4, Bild 1 von 1
    • Opening the two halves of the calculator reveals a foil shield over the rest of the electronics.
    • Remove four Phillips screws to access the electronics underneath, then pull the shield away.
    Frag FixBot
  5. Texas Instruments TI-82 Teardown: Schritt 5, Bild 1 von 1
    • ... And, here's the guts of the thing.
    • SRM20255LLM10 / F4ZM1938 (32Kbyte SRAM)
    • LH531GP4 (Mask ROM)
    • T 84C00AM-8 (Z80 CPU)
    • Toshiba / TC14L010AF / 1273 9506EAI (ASIC)
    Frag FixBot
  6. Texas Instruments TI-82 Teardown: Schritt 6, Bild 1 von 2 Texas Instruments TI-82 Teardown: Schritt 6, Bild 2 von 2
    • Remove the remaining Phillips screws.
    • The screen and main board will lift out, leaving the membrane keypad in the front case.
    Frag FixBot
bushing
10.502 Reputation
13 Anleitungen geschrieben
1 Kommentar zur Anleitung
Minor correction, the RAM part is SRM20256LLM10, a CMOS 256 kilobit (32x8) 100ns static RAM in 28 pin SOP form factor.
Nick M - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 31
Letzte 30 Tage: 94
Insgesamt: 22,955
