Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Texas Insturments TI-84 Plus Color Silver Edition zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: Schritt 1, Bild 1 von 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: Schritt 1, Bild 2 von 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: Schritt 1, Bild 3 von 3
    • Wisdom
  2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: Schritt 2, Bild 1 von 2 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: Schritt 2, Bild 2 von 2
    • Unplug the battery.
    • Be careful not to fray cable while unplugging.
  3. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: Schritt 3, Bild 1 von 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: Schritt 3, Bild 2 von 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: Schritt 3, Bild 3 von 3
    • Remove the back cover by removing the 6 Pentalobe screws (P6)
    • The front cover can be taken off by prying it off from the front of the device
    • Then pry off the back cover it can be a little challenging but take your time
  4. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: Schritt 4, Bild 1 von 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: Schritt 4, Bild 2 von 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: Schritt 4, Bild 3 von 3
    • Remove the 6 Philips screws holding the mother board and if you want remove the foil just to see the full board itself
    • To change out the buttons take out the grey rubber sheet that separates them from the board (be careful with the buttons as they will fall out)
ArabianBoi1259
103 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 1,097
