Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Timex TX5020 LCD Electronic Thermometer zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Timex TX5020 LCD Electronic Thermometer Teardown, Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 1, Bild 1 von 2 Timex TX5020 LCD Electronic Thermometer Teardown, Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 1, Bild 2 von 2
    • Here is the fully assembled thermometer.
  2. Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 2, Bild 1 von 1
    • Slide the battery compartment cover off by applying downward and forward pressure.
  3. Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 3, Bild 1 von 2 Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 3, Bild 2 von 2
    • Loosen and remove the four screws from the back of the thermometer.
  4. Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 4, Bild 1 von 1
    • Lift the back panel away from the rest of the case.
  5. Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 5, Bild 1 von 2 Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 5, Bild 2 von 2
    • Remove the three screws holding the circuit board in place.
  6. Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 6, Bild 1 von 2 Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 6, Bild 2 von 2
    • Lift the circuit board away from the case.
    • Be careful not to pull too hard as the board is attached to the battery contacts.
  7. Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 7, Bild 1 von 2 Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 7, Bild 2 von 2
    • Remove the screen from its compartment.
    • Remove the push buttons from their compartment.
  8. Timex TX5020 LCD Electronic Thermometer Teardown: Schritt 8, Bild 1 von 1
    • Here's a full view of the disassembled components (circuit board, screen, push buttons, and case).
Chris L
1.522 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,761
