Einleitung
This guide is a step-by-step teardown of a Toaster Made by Design model KT-3215. The purpose of the guide is to provide a look into the internals of the toaster. This teardown is not intended to be followed for repair.
Was du brauchst
This is what a Toaster Made by Design model KT-3215 should look like before the teardown has started.
Remove the crumb tray, which is located on the back of the toaster. Slide the crumb tray directly out. No lifting or twisting is required.
Use your index finger and middle finger to grip the loading lever, then pull towards your body to remove the lever. A fair amount of force may be required.
Use a TA 2.3 screwdriver to unscrew the five triangular screws on the bottom of the toaster.
Lift the toaster casing. This will expose the power splitter cable (white cable).
Use a spudger and your thumb, to remove the power splitter cable.
Place the toaster casing upside down.
Use a Phillips #2 x 4in. screwdriver to remove the four 0.25 in. Phillips head screws. These screws are securing the control board for the buttons and timer knob.
Pull the bagel button and cancel button off of the toaster casing. These buttons require little force to remove.
Detach the timer knob by pinching the sides of the timer knob and pushing towards the exterior of the toaster casing.
Use a pair of mini long-nose pliers to remove the spring components from the timer knob.
Use a pair of mini long-nose pliers to bend the metal lips located on the back of the toaster. The metal lips should be facing towards you after you have bent them.
Remove the waveguide cover (rectangular tan cover) on the back of the toaster.
Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. This will allow you to remove the metal bracket.
Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. These screws secure the back of the internal housing of the toaster.
Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. These screws secure the front of the internal housing of the toaster.
Lift the internal housing.
Use a pair of mini needle pliers to remove the other end of the power splitter cable.
Place the internal housing flat on the base of the toaster.
Use a pair of mini long-nose pliers to detach the wires that are welded to the internal housing. This may require some force.
Use a Phillips #2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws from the plastic fastener.
Remove the plastic fastener.
Remove the main electric controller by gently pushing forward on it then raising it up.
Pull the power cord through the base of the toaster. This will allow separation between the base of the toaster and the main electric controller.
The teardown of a Toaster Made by Design Model model KT-3215 is now complete.
