Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
This guide will show how to take the back housing off the Tablet portion and the keyboard cover.
  1. After this procedure there seemed to be more back light bleed on my tablet.  Not sure if it was there before so be careful. Remove the tablet from the dock.
    • After this procedure there seemed to be more back light bleed on my tablet. Not sure if it was there before so be careful.
    • Remove the tablet from the dock.
    • Find the best place to insert your plastic pry tool (I used the Micro-SD slot). Carefully go around the perimeter of the tablet and unclip the back cover.
    • Take note off all the clips. The back cover is held in place with a ton of these all around.
  2. Once you have the back cover off you are free to replace what you'd like. Msata SSD Part #MZMTE128HMGR-0000 M.2 2230 WiFi Model #7260NGW
    • Once you have the back cover off you are free to replace what you'd like.
    • Msata SSD Part #MZMTE128HMGR-0000
    • M.2 2230 WiFi Model #7260NGW
  3. Battery Model #PA5190U-1BRS Motherboard Part #DAOZC1MBADO REV:D Capacitive button/dock board Part #3TCZ1T80000
    • Battery Model #PA5190U-1BRS
    • Motherboard Part #DAOZC1MBADO REV:D
    • Capacitive button/dock board Part #3TCZ1T80000
    • Re-assembly in reverse order.
  4. With the keyboard separated remove all the screws in the bottom. The top 4 screws are longer then the bottom 6. Keyboard back cover Part #ZYE35CZ1BA0100140810-01 REV:3A Keyboard boards and weights.
    • With the keyboard separated remove all the screws in the bottom. The top 4 screws are longer then the bottom 6.
    • Keyboard back cover Part #ZYE35CZ1BA0100140810-01 REV:3A
    • Keyboard boards and weights.
  5. The keyboard dock board.  Looks like there is a way to add a second HDD/SSD here but the connector is not soldered on. Keyboard board Part #CZ1D30E51001CC Mouse board, left-hand weight, front LED board.
    • The keyboard dock board. Looks like there is a way to add a second HDD/SSD here but the connector is not soldered on.
    • Keyboard board Part #CZ1D30E51001CC
    • Mouse board, left-hand weight, front LED board.
Sasa Macura
177 Reputation
2 Anleitungen geschrieben
3 Kommentare
lindas fotos pero no hay un video que muestre como demontar la tapa.
ximena - Antwort
muy ilustrativas las imagenes.. tendras algunas donde se vea el mecanismo del teclado donde sujeta a la pantalla ?
carlos - Antwort
i need keyboard for this lap how i can get it
Hussien Mahmoud - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 6
Letzten 30 Tage: 25
Insgesamt: 7,234
