Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Was du brauchst
  1. Toshiba Click 2 Pro P35W-B3226 Teardown, Back Cover: Schritt 1, Bild 1 von 2 Toshiba Click 2 Pro P35W-B3226 Teardown, Back Cover: Schritt 1, Bild 2 von 2
    • After this procedure there seemed to be more back light bleed on my tablet. Not sure if it was there before so be careful.
    • Remove the tablet from the dock.
    • Find the best place to insert your plastic pry tool (I used the Micro-SD slot). Carefully go around the perimeter of the tablet and unclip the back cover.
    • Take note off all the clips. The back cover is held in place with a ton of these all around.
    Where is the memory chip? Thank you.
    J L - Antwort
  2. Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 1: Schritt 2, Bild 1 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 1: Schritt 2, Bild 2 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 1: Schritt 2, Bild 3 von 3
    • Once you have the back cover off you are free to replace what you'd like.
    • Msata SSD Part #MZMTE128HMGR-0000
    • M.2 2230 WiFi Model #7260NGW
  3. Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 2: Schritt 3, Bild 1 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 2: Schritt 3, Bild 2 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 2: Schritt 3, Bild 3 von 3
    • Battery Model #PA5190U-1BRS
    • Motherboard Part #DAOZC1MBADO REV:D
    • Capacitive button/dock board Part #3TCZ1T80000
    • Re-assembly in reverse order.
  4. Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Disassembly: Schritt 4, Bild 1 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Disassembly: Schritt 4, Bild 2 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Disassembly: Schritt 4, Bild 3 von 3
    • With the keyboard separated remove all the screws in the bottom. The top 4 screws are longer then the bottom 6.
    • Keyboard back cover Part #ZYE35CZ1BA0100140810-01 REV:3A
    • Keyboard boards and weights.
    Where can I buy the screws? email me back at nkaur20@uic.edu
    Neha Kaur - Antwort
  5. Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Parts: Schritt 5, Bild 1 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Parts: Schritt 5, Bild 2 von 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Parts: Schritt 5, Bild 3 von 3
    • The keyboard dock board. Looks like there is a way to add a second HDD/SSD here but the connector is not soldered on.
    • Keyboard board Part #CZ1D30E51001CC
    • Mouse board, left-hand weight, front LED board.
Sasa Macura
177 Reputation
2 Anleitungen geschrieben
3 Kommentare
lindas fotos pero no hay un video que muestre como demontar la tapa.
ximena - Antwort
muy ilustrativas las imagenes.. tendras algunas donde se vea el mecanismo del teclado donde sujeta a la pantalla ?
carlos - Antwort
i need keyboard for this lap how i can get it
Hussien Mahmoud - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 7,430
