Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Uniden EXP 371 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Uniden EXP 371 Teardown, Uniden EXP 371 Teardown: Schritt 1, Bild 1 von 1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Teardown: Schritt 2, Bild 1 von 2 Uniden EXP 371 Teardown: Schritt 2, Bild 2 von 2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Teardown: Schritt 3, Bild 1 von 2 Uniden EXP 371 Teardown: Schritt 3, Bild 2 von 2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Teardown: Schritt 4, Bild 1 von 3 Uniden EXP 371 Teardown: Schritt 4, Bild 2 von 3 Uniden EXP 371 Teardown: Schritt 4, Bild 3 von 3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
Tim Reimer
165 Reputation
3 Anleitungen geschrieben
Ein Kommentar
this guide is poorly written, please delete or improve it.
Walker Quine - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 4,569
