Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein VOOM zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Vixt VOOM Disposable Teardown, Popping the cap: Schritt 1, Bild 1 von 3 Vixt VOOM Disposable Teardown, Popping the cap: Schritt 1, Bild 2 von 3 Vixt VOOM Disposable Teardown, Popping the cap: Schritt 1, Bild 3 von 3
    • The user manual had a nice x-ray view of the device.
    • The mouthpiece has a really good fit and required some force to remove. But you only need to pinch and pull, hard.
    • There is a fluid capturing pad in the mouthpiece and a silicone seal to prevent it from leaking, non of them was glued or secured in any noticeable way.
  2. Vixt VOOM Disposable Teardown, Undressing: Schritt 2, Bild 1 von 3 Vixt VOOM Disposable Teardown, Undressing: Schritt 2, Bild 2 von 3 Vixt VOOM Disposable Teardown, Undressing: Schritt 2, Bild 3 von 3
    • Nothing clipped or glued into place so far, just pinch and pull.
    • Nice little Li-po battery inside. Quite a waste to market this product as disposable with a rechargeable battery inside.
  3. Vixt VOOM Disposable Teardown, Cotton swabs: Schritt 3, Bild 1 von 3 Vixt VOOM Disposable Teardown, Cotton swabs: Schritt 3, Bild 2 von 3 Vixt VOOM Disposable Teardown, Cotton swabs: Schritt 3, Bild 3 von 3
    • The way the mouthpiece pops off and how the tank is built up it's definitely reusable, however the battery charge is a big problem.
  4. Vixt VOOM Disposable Teardown, Guts: Schritt 4, Bild 1 von 3 Vixt VOOM Disposable Teardown, Guts: Schritt 4, Bild 2 von 3 Vixt VOOM Disposable Teardown, Guts: Schritt 4, Bild 3 von 3
    • The tank was clipped on, but came loose fairly easy.
    • Couldn't remove the coil or the leads to the coil, and doing so would result in leakage due to the leads being sealed towards the tank with silicone goop.
    • The x-ray on the user manual indicated some more cotton between the tank/coil and cradle, but couldn't reach it.
  5. Vixt VOOM Disposable Teardown: Schritt 5, Bild 1 von 3 Vixt VOOM Disposable Teardown: Schritt 5, Bild 2 von 3 Vixt VOOM Disposable Teardown: Schritt 5, Bild 3 von 3
    • The chip seems to only be a switch to switch on and off the coil when you draw, and in doing so also activate the blue LED, nothing fancy here.
    • Modifying this to be rechargeable wouldn't be to hard if you get this far, since there is a lot of space in the battery cradle, for making contacts and such, but you'd need to get a charging circuit into it somewhere which might pose a problem.
    • Wouldn't recommend it though since the coil has an expected end of life after certain cycles, and isn't replaceable.
  6. Vixt VOOM Disposable Teardown, Laid to bare: Schritt 6, Bild 1 von 1
    • All parts (that i could take apart) in one picture.
    • My thoughts. All in all, this is a very wasteful product marketed as disposable, not only does it contain a poisonous concentration of nicotine, it also houses a rechargeable battery that you can't really recharge in any easy way. The reusable model is a a few extra bucks but you can recharge it, and replace the battery if need be.
David
921 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 2,548
