Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Wahl Cordless Beard Trimmer zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Wahl Cordless Beard Trimmer Teardown, Remove battery cover: Schritt 1, Bild 1 von 2 Wahl Cordless Beard Trimmer Teardown, Remove battery cover: Schritt 1, Bild 2 von 2
    • Begin by removing the battery cover from the back of the trimmer.
  2. Wahl Cordless Beard Trimmer Teardown, Remove battery: Schritt 2, Bild 1 von 2 Wahl Cordless Beard Trimmer Teardown, Remove battery: Schritt 2, Bild 2 von 2
    • Remove the battery.
  3. Wahl Cordless Beard Trimmer Teardown, Remove metal blade: Schritt 3, Bild 1 von 3 Wahl Cordless Beard Trimmer Teardown, Remove metal blade: Schritt 3, Bild 2 von 3 Wahl Cordless Beard Trimmer Teardown, Remove metal blade: Schritt 3, Bild 3 von 3
    • Remove the screws, then gently lift off the blade. A small piece of plastic should come off with the blade. There will be a spring revealed from under the blade, remove this as well.
  4. Wahl Cordless Beard Trimmer Teardown, Separate plastic cover: Schritt 4, Bild 1 von 2 Wahl Cordless Beard Trimmer Teardown, Separate plastic cover: Schritt 4, Bild 2 von 2
    • Remove the screws from the sides of the battery compartment. Then, gently separate the two halves of the plastic cover.
  5. Wahl Cordless Beard Trimmer Teardown, Remove switch: Schritt 5, Bild 1 von 2 Wahl Cordless Beard Trimmer Teardown, Remove switch: Schritt 5, Bild 2 von 2
    • Lay both halves of the trimmer out, and remove the switch from the inside of the white plastic cover.
  6. Wahl Cordless Beard Trimmer Teardown, Remove motor: Schritt 6, Bild 1 von 2 Wahl Cordless Beard Trimmer Teardown, Remove motor: Schritt 6, Bild 2 von 2
    • Finally, remove the motor from the black plastic cover. If desired, this motor can be de-soldered from the red wire and re-purposed.
arielletc28
167 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 35
Letzte 30 Tage: 181
Insgesamt: 17,067
