Was du brauchst
Teardown of Water Dancing Speaker
Remove 4 screws from rear of speaker
Peel back the rear half of the shell
Remove the Water/Pump Chamber
Remove 2 screws that hold the logic circuit in place
Carefully pull the logic board up, out of the plastic slot
Remove the 3 screws holding the speaker
Remove the speaker from the plastic shell
Disconnect the battery connector from the logic board
Disconnect the motor connector from the logic board
Disconnect the speaker connector from the logic board
Disconnect the LED connector from the logic board
Remove the 2 screws holding the motor mount on the water/pump chamber
Remove the motor mount from the water/pump chamber
Remove the 2 screws holding the LED board on the water/pump.
Remove the LED board from the water/pump
