Zum Hauptinhalt wechseln
Xbox Disassembly
Was du brauchst
Einführungsvideo
  1. Xbox Disassembly, Xbox Disassembly: Schritt 1, Bild 1 von 1
    • Start with your Xbox unplugged and sitting on a flat, stable surface.
  2. Xbox Disassembly: Schritt 2, Bild 1 von 1
    • Flip the Xbox over and pry off the rubber feet with a metal spudger.
  3. Xbox Disassembly: Schritt 3, Bild 1 von 2 Xbox Disassembly: Schritt 3, Bild 2 von 2
    • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
  4. Xbox Disassembly: Schritt 4, Bild 1 von 1
    • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
  5. Xbox Disassembly: Schritt 5, Bild 1 von 2 Xbox Disassembly: Schritt 5, Bild 2 von 2
    • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
  6. Xbox Disassembly: Schritt 6, Bild 1 von 2 Xbox Disassembly: Schritt 6, Bild 2 von 2
    • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Disassembly: Schritt 7, Bild 1 von 2 Xbox Disassembly: Schritt 7, Bild 2 von 2
    • Lift the hard drive storage unit out of the Xbox. It should come right out.
    • Take the power cable out of the track around the hard drive so that the unit will come out easier.
  8. Xbox Disassembly: Schritt 8, Bild 1 von 3 Xbox Disassembly: Schritt 8, Bild 2 von 3 Xbox Disassembly: Schritt 8, Bild 3 von 3
    • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
    • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
  9. Xbox Disassembly: Schritt 9, Bild 1 von 2 Xbox Disassembly: Schritt 9, Bild 2 von 2
    • Unplug both the ribbon cable and power cable from hard drive.
    • They are in there pretty tightly, so this may take some effort.
  10. Xbox Disassembly: Schritt 10, Bild 1 von 3 Xbox Disassembly: Schritt 10, Bild 2 von 3 Xbox Disassembly: Schritt 10, Bild 3 von 3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  11. Xbox Disassembly: Schritt 11, Bild 1 von 1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
  12. Xbox Disassembly: Schritt 12, Bild 1 von 1
    • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
  13. Xbox Disassembly: Schritt 13, Bild 1 von 2 Xbox Disassembly: Schritt 13, Bild 2 von 2
    • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
  14. Xbox Disassembly: Schritt 14, Bild 1 von 2 Xbox Disassembly: Schritt 14, Bild 2 von 2
    • Remove the power supply and set it aside. It should lift right out.
  15. Xbox Disassembly: Schritt 15, Bild 1 von 2 Xbox Disassembly: Schritt 15, Bild 2 von 2
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  16. Xbox Disassembly: Schritt 16, Bild 1 von 2 Xbox Disassembly: Schritt 16, Bild 2 von 2
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  17. Xbox Disassembly: Schritt 17, Bild 1 von 1
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
  18. Xbox Disassembly: Schritt 18, Bild 1 von 1
    • Pry the plastic fan clips away from the fan base and remove the fan.
    • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
  19. Xbox Disassembly: Schritt 19, Bild 1 von 2 Xbox Disassembly: Schritt 19, Bild 2 von 2
    • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
    • Take the sockets out by pulling back and up at the same time.
  20. Xbox Disassembly: Schritt 20, Bild 1 von 1
    • Congratulations, your Xbox is now completely dismembered.
Abschluss
48 weitere Nutzer:innen haben diese Anleitung absolviert.
rmarstel
5.674 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 18-2, Maness Fall 2009 Mitglied von Cal Poly, Team 18-2, Maness Fall 2009
CPSU-MANESS-F09S18G2
3 Mitglieder
24 Anleitungen geschrieben
10 Kommentare
Awesomeness, thanks a lot!
godoyander - Antwort
Thanks a million - perfect!
xan_lucky16 - Antwort
Heatsink removal?
Matt Russell - Antwort
Face plate removal?
Herberth Alvarez - Antwort
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 59
Letzte 7 Tage: 469
Letzte 30 Tage: 1,854
Insgesamt: 179,983
