Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Xiaomi Mi Power Bank 10400mAh zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Xiaomi Mi Power Bank  10400mAh Teardown, Xiaomi Mi Power Bank  10400mAh Teardown: Schritt 1, Bild 1 von 1
    • This is the model
  2. Xiaomi Mi Power Bank  10400mAh Teardown: Schritt 2, Bild 1 von 3 Xiaomi Mi Power Bank  10400mAh Teardown: Schritt 2, Bild 2 von 3 Xiaomi Mi Power Bank  10400mAh Teardown: Schritt 2, Bild 3 von 3
    • Remove it with a knife. Be really careful not to cut yourself
    • The top is attached with double sided tape.
  3. Xiaomi Mi Power Bank  10400mAh Teardown: Schritt 3, Bild 1 von 1
    • Remove 4 screws, and push the battery and circuit board out.
    • You need to resolder the battery to the PCB.
    • To keep the battery tight I used a piece of double sided foam tape on on of the edge cells
Martin Hampton
1.308 Reputation
7 Anleitungen geschrieben
2 Kommentare
Umm there’s missing steps - the bottom cover also needs removed? How do you push the battery out? Both sides are screwed in please help or finish t his guide thanks
emanoyhl - Antwort
Hi emanoyhl, this guide is a teardown and it looks like it is still in progress, so it's not totally complete yet. I did a search and found a guide for a similar device but for the LED however it does show a little more of the internals. Check out the Jerking LED fix in 10000mAh Mi Power Bank 2S, it's not exactly the same device but it seems to have similar construction and you might be able to reach the battery the same way? I hope this helps!
Sarah Westberg -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 103
Insgesamt: 4,966
