Was du brauchst
Start by pressing the power button for 5 seconds.
Click on shutdown after the menu appears. Then click the button again.
Insert your Opener Pick (or your finger nail) into the gap.
Slide the pick (or your finger nail) through the whole perimeter of the phone until all the clips are uncliped.
Remove the eight screws on the top panel.
Now the top panel will be loose, just pull it out with a little bit of force.
Put your finger nail under the battery connector.
With a little bit of force, push it upwards. It should detach from the Main board's connected.
Remove the eight screws on the bottom panel.
Now the bottom panel, like the top panel, should easily come out with a little bit of force.
Remove the connector the same Way we removed the battery connector.
Detach the LCD touch cable
Detach the Antena cable
Remove the entire CC board
Remove the screw behind the head phone jack and all the flex cables still attached to the Main board.
The board should easily come out now
Remove the antenna connected to the board
With the opener pick, remove the battery and we are done!
Follow the steps in reverse to reassemble the phone!
