Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Xtorm XB304 Titan zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Xtorm XB304 Titan Teardown, Xtorm XB304 Titan Teardown: Schritt 1, Bild 1 von 3 Xtorm XB304 Titan Teardown, Xtorm XB304 Titan Teardown: Schritt 1, Bild 2 von 3 Xtorm XB304 Titan Teardown, Xtorm XB304 Titan Teardown: Schritt 1, Bild 3 von 3
    • The battery configuration seems to be 4S2P, with custom 18650 Li-Ion cells.
    • Two circuit boards are on the USB plug end, with large inductors inbetween, that are stuck in place with white silicon(?) glue.
    • The heat conducting grey foam has some sort of black heat spreader under it, with the thermocouple attached to that - the heat spreader seems to go below the (heat isolating?) white sticky foam that is over the battery part.
    • I didn't risk disassembling my power bank any further as I still need it - there seem to be phillips screws holding down the circuit board though.
  2. Xtorm XB304 Titan Teardown: Schritt 2, Bild 1 von 3 Xtorm XB304 Titan Teardown: Schritt 2, Bild 2 von 3 Xtorm XB304 Titan Teardown: Schritt 2, Bild 3 von 3
    • The circuit board has the battery balancing circuitry directly on it, there isn't a seperate battery protection board.
    • The case seems to provide reasonable physical protection of the cells from sharb objects with double walls.
    • I didn't research any of the chips, they don't have the marking removed though.
ekalf
85 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 796
