Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein ZEN V Creative Media Player zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. ZEN V Creative Media Player Teardown, ZEN V Creative Media Player Teardown: Schritt 1, Bild 1 von 3 ZEN V Creative Media Player Teardown, ZEN V Creative Media Player Teardown: Schritt 1, Bild 2 von 3 ZEN V Creative Media Player Teardown, ZEN V Creative Media Player Teardown: Schritt 1, Bild 3 von 3
    • Here we have Creative's ZEN V Media Player.
    • The Navigator Stick
    • The Play/Pause Button
    • The Back Button
    • The LCD
    • USB 2.0 Charging Port
    • Headphone Jack
    • Line In Jack
  2. ZEN V Creative Media Player Teardown: Schritt 2, Bild 1 von 3 ZEN V Creative Media Player Teardown: Schritt 2, Bild 2 von 3 ZEN V Creative Media Player Teardown: Schritt 2, Bild 3 von 3
    • Start by taking a pointy metal spudger and insert it on the bottom edge of the player
    • Slide it along, prying up until a gap forms
    • Proceed to insert and slide the tool along the left and right side of the device, until the plastic piece with the buttons comes free.
    • Half of the covering plastic should be off now
    • Gap between plastics
  3. ZEN V Creative Media Player Teardown: Schritt 3, Bild 1 von 3 ZEN V Creative Media Player Teardown: Schritt 3, Bild 2 von 3 ZEN V Creative Media Player Teardown: Schritt 3, Bild 3 von 3
    • While doing the following steps note that this piece is glued on to the LCD. Do not apply too much force or shove your tool too far in
    • Glue
    • Bring your tool to the top edge of the player and insert it
    • Insert it on the top edge and slide while prying up
    • The gap
    • Insert it on the two sides and pry until plastic comes loose
  4. ZEN V Creative Media Player Teardown: Schritt 4, Bild 1 von 2 ZEN V Creative Media Player Teardown: Schritt 4, Bild 2 von 2
    • Be very gentle with the LCD in the next 2 steps! It is glued to the logic board with black stick pads. Do not break the cable/clip!
    • Adhesive Pads
    • Cable Clip
    • Insert flat end of plastic spudger on the bottom of the LCD. Pry gently upwards.
    • Bottom of LCD
    • Insert on the sides and continue to pry.
    • Finally insert on the top and pry.
    • Top of LCD
  5. ZEN V Creative Media Player Teardown: Schritt 5, Bild 1 von 3 ZEN V Creative Media Player Teardown: Schritt 5, Bild 2 von 3 ZEN V Creative Media Player Teardown: Schritt 5, Bild 3 von 3
    • Pull back LCD to bottom of player to expose cable/clip
    • Remove orange ESD safe tape with spudger/fingernail
    • Orange ESD safe tape
    • Flip up the clip with flat end of spudger/fingernail
    • Clip is flipped up
    • Pull the LCD away from the player
  6. ZEN V Creative Media Player Teardown: Schritt 6, Bild 1 von 3 ZEN V Creative Media Player Teardown: Schritt 6, Bild 2 von 3 ZEN V Creative Media Player Teardown: Schritt 6, Bild 3 von 3
    • Put down your spudger and pick up a Phillips #000 Screwdriver
    • Remove the two screws on the logic board
    • Screws
    • Remove Volume control button by pulling it up off the board
    • Volume control button
    • Pull up board from bottom of player
    • Gently wiggle the logic board out of the casing. Be careful because it is connected to a battery underneath it
    • Battery
  7. ZEN V Creative Media Player Teardown: Schritt 7, Bild 1 von 3 ZEN V Creative Media Player Teardown: Schritt 7, Bild 2 von 3 ZEN V Creative Media Player Teardown: Schritt 7, Bild 3 von 3
    • Insert spudger under the top of the battery and pry
    • Top half of battery
    • There is an adhesive pad under the battery
    • Battery should now be free
    • Remove battery from case and set aside connected to the logic board
  8. ZEN V Creative Media Player Teardown: Schritt 8, Bild 1 von 1
    • Battery may now be removed from logic board with a soldering iron
    • Heat up the contacts and pull away wires
    • Contacts
  9. ZEN V Creative Media Player Teardown: Schritt 9, Bild 1 von 2 ZEN V Creative Media Player Teardown: Schritt 9, Bild 2 von 2
    • These all are various components that can be removed with a soldering iron
    • USB 2.0 Port has 4 pads and 5 pins attaching it to the logic board
    • Various Switches- 4 pads each. From the (Bottom left), Volume up, Volume Down, Mute?, (Top Left), Power on/Hold, Reset
    • Line In Jack 4 pads
    • Headphone Jack 4 pads
    • Play/Pause Button 2 pads and Back Button 2 pads
    • LCD connector and Navigtor button
  10. ZEN V Creative Media Player Teardown: Schritt 10, Bild 1 von 1
    • All the innards of the ZEN V Media Player
    • Button Plastic- Removed in Step 2
    • LCD Plastic- Removed in Step 3
    • Orange ESD Safe tape and LCD Screen- Removed in Step 5
    • Screws and Volume Button- Removed in Step 6
    • Back Plastic Case and Logic Board- Removed in Step 7
    • Battery Removed in Step 8
Liam Speirs
363 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 13,674
