Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Was du brauchst
  1. iMac G3 Model M4984 Teardown, Logic Board: Schritt 1, Bild 1 von 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Teardown: Schritt 2, Bild 1 von 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Teardown: Schritt 3, Bild 1 von 3 iMac G3 Model M4984 Teardown: Schritt 3, Bild 2 von 3 iMac G3 Model M4984 Teardown: Schritt 3, Bild 3 von 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Teardown: Schritt 4, Bild 1 von 3 iMac G3 Model M4984 Teardown: Schritt 4, Bild 2 von 3 iMac G3 Model M4984 Teardown: Schritt 4, Bild 3 von 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Teardown: Schritt 5, Bild 1 von 3 iMac G3 Model M4984 Teardown: Schritt 5, Bild 2 von 3 iMac G3 Model M4984 Teardown: Schritt 5, Bild 3 von 3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Teardown: Schritt 6, Bild 1 von 2 iMac G3 Model M4984 Teardown: Schritt 6, Bild 2 von 2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Teardown: Schritt 7, Bild 1 von 3 iMac G3 Model M4984 Teardown: Schritt 7, Bild 2 von 3 iMac G3 Model M4984 Teardown: Schritt 7, Bild 3 von 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Teardown: Schritt 8, Bild 1 von 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Teardown, Bottom Cover: Schritt 9, Bild 1 von 1
    • To remove the bottom cover, remove these phillips screws, and pull the bottom cover off the iMac. (Start with the very back and use a flat head screwdriver to pop the main clip. The rest will come off relatively easily.)
  10. iMac G3 Model M4984 Teardown: Schritt 10, Bild 1 von 3 iMac G3 Model M4984 Teardown: Schritt 10, Bild 2 von 3 iMac G3 Model M4984 Teardown: Schritt 10, Bild 3 von 3
    • Removing the faceplate:
    • Remove these phillips screws.
    • Now, pivot the faceplate up about 60 degrees and pull it away from the imac, with some wiggleing, it should come free
Chris Green
36.978 Reputation
49 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.521 Anleitungen geschrieben
Ein Kommentar
yo what happened to this lmao
Crystal Haugh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 9,127
