Zum Hauptinhalt wechseln
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein iMac Intel 21.5" Retina 4K Display 2019 zu reparieren, verwende unsere Fehlerbehebungsseite.
    1. iMac Intel 21.5" Retina 4K Display 2019 Teardown, iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 1, Bild 1 von 1
      • Apple has surprised us all by unveiling some new iMacs without a Keynote.
      • But what has surprised us most by far are the big specs this little iMac packs.
      • 8th generation Intel Core i3 quad-core processor clocked at 3.6GHz
      • 8GB of DDR4 RAM Running at a speed of 2400MHz
      • A mediocre 1 TB mechanical hard disk drive.
      • AMD Radeon Pro 555X graphics card with 2GB of GDDR5 video RAM.
      • And of course the gorgeous 4K Retina Display with support for the P3 color gamut.
      Frag FixBot
      Kommentar hinzufügen
    2. iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 2, Bild 1 von 2 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 2, Bild 2 von 2
      • Opening the iMac has never been easier with ifixit opening tool.
      • I did use these 6 tools
      Frag FixBot
    3. iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 3, Bild 1 von 2 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 3, Bild 2 von 2
      • It was really disappointing to see nothing is changed in this iMac in last 2 years.
      Frag FixBot
    4. iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 4, Bild 1 von 2 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 4, Bild 2 von 2
      • it seems they have changed the LCD connecters only
      • The large LCD screen is made by LG Display.
      Frag FixBot
    5. iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 5, Bild 1 von 3 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 5, Bild 2 von 3 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 5, Bild 3 von 3
      • Only wifi and bluetooth module in now fixed on the board. Hard drive still same Hitachi 5400 rpm and fan still the same as you can see
      Frag FixBot
    6. iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 6, Bild 1 von 3 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 6, Bild 2 von 3 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 6, Bild 3 von 3
      • A protection cover for the RAMs which I think is not necessary for a fixed device like this and as you know 2666 MHz DDR4 rams are little higher speed than the 2017 model.
      Frag FixBot
    7. iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 7, Bild 1 von 2 iMac Intel 21.5" Retina 4K Display 2019 Teardown: Schritt 7, Bild 2 von 2
      • Insert wisdom here.
      Frag FixBot
    8. iMac Intel 21.5" Retina 4K Display 2019 Teardown, Power Supply: Schritt 8, Bild 1 von 3 iMac Intel 21.5" Retina 4K Display 2019 Teardown, Power Supply: Schritt 8, Bild 2 von 3 iMac Intel 21.5" Retina 4K Display 2019 Teardown, Power Supply: Schritt 8, Bild 3 von 3
      • Power supply
      • If not handled correctly, the power supply can do bodily harm.
      Frag FixBot
Babak
188 Reputation
1 Anleitung geschrieben
Hedmontech Trading L.L.c Mitglied von Hedmontech Trading L.L.c
Business
1 Mitglied
12 Anleitungen geschrieben
29 Kommentare zur Anleitung
Dear Good day
ill purchase new 21 2019 it can upgrade ram 2666GHz 32GB
yes or no
Mohamed Ghaly - Antwort Teilen
yes you can upgrade to 64 GB too if you have access to OWC company
Babak - Antwort Teilen
Hi Mohammad:
It is possible to make it 32 GB but you need to be a little gentle when doing that. feel free to ask me here if you face any issue. I actully made a video for the first time doing it you can have look at it to get some idea.
https://www.youtube.com/watch?v=IPjkR8Eo...
Goodness me, they didn’t cover the PSU! How disgraceful of Apple!
Jessica Parnelli Fawkes - Antwort Teilen
they never cover that since day first of creating iMacs
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 47
Letzte 30 Tage: 239
Insgesamt: 47,260
