Was du brauchst
Einführungsvideo
- The USB-C port is modular and can be independently replaced.
- The lack of a physical home button eliminates a common failure point and may simplify repairs.
- The battery is secured with both easier-to-remove stretch-release tabs and conventional, non-removable adhesive.
- The LCD and front panel glass are fused together—simplifying the opening procedure, but increasing the cost of repair.
- Gobs of adhesive hold most everything in place, making all repairs more difficult.
Fazit
Reparierbarkeits-Index
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter-background.png)
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter.png)
3
Reparierbarkeit 3 von 10
(10 ist am einfachsten zu reparieren)
8 Kommentare
Who manufactures the LiDAR hardware?
Shaun O'Flaherty - Antwort
Looks like a ToF not real LiDAR. Apple marketing spin again
i.thanh -
https://tof-insights.com/time-of-flight-... Goes into details on pros and cons of a ToF versus LiDAR - and it appears there are many reasons why it makes sense to do a TOF LiDAR versus a full system when we are talking about a mobile device. Marketing spin, I hardly think so. It’s achieving the same functionality with many benefits on the device end.
Andrew C. A. -
When are you going to get a look at the IC’s in this?
Sean Davis - Antwort
it actually is a lidar and not a time of flight camera
cool tech with mick - Antwort
